Question about GE 31GT740 31" TV
How can i fix a rca tv, mod. 27v412t cuts on and off?
My tv goes off and on it a bad power button and down volume bad. and i still cuts on and off so i removed the power button thinking i can turn it off and on with the remote, that didn't work neither.
    Problem Solver:
  • 5 Answers
Have you checked the power plug, sometimes when the power plug is not on securely on both ends of it, that can happen. It could also be defected wires on the inside of your tv. So check both ends. LOL
God Bless!
Posted on May 30, 2014
    Problem Solver:
  • 10 Answers
This kind off problem is related in power circuit board or may be the main board ,kind of electronic problem, not mechanical ,related with electrolytic capacitor,may be two or three or one,this is dried up capacitor,or devalued capacitor in rating or leaky capacitor,or broken leg capacitor,one pin break in the bottom of capacitor main causes are heat or power serge or getting aging old ,because these capacitor not functioning ,therefore no enough voltage for on off TV function,so TV wont come on,some times come on,some time press power button lot of time then come on,now it wont come on at all completely,these or the symptom of intemittent power button function,peoples think that button have only the problem and replaced the power switch only and tv should work ,but deep down lot of work in circuit board analysis and repair work needed.,to make TV function normally.
Posted on May 19, 2014
3 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: 35 in. GE tube TV volume issue
The front panel control assembly, or the circuit area for this panel most likely has a fault condition.
I have also seen some of the button switches fail on the control panel.
Jerry G.
Posted on Feb 10, 2009
  • 31 Answers
SOURCE: I set a lock out code for a channel several years
http://www.fixya.com/support/p237180-ge_31gt720_31_tv/manual-11918/page-34
This URL takes you to a complete user's manual for your television set. Perhaps you can find what you want there.
Posted on Oct 21, 2010
RCA Model 27V412T Trying to fix the screen size. The edges are cut off
When the picture gets smaller that means the high voltage being applied to the picture tube is failing. The flyback transformer and the horizontal output transistor are the likely parts that fail. Power supply capacitors that have domed tops are suspect too. Parts and labor for a TV that old may surpass the price of a new TV.
Sep 08, 2016 | RCA Televison & Video
T.v. turns on and off by it self also will do auto search by itself
The microprocessor ic is breaking down or the pad switches behind the buttons on the front of the set, "one or two are bad" disable the front panel by unplugging from main board, if problem goes away use remote to control set.
Mar 19, 2012 | RCA Televison & Video
How to take of the FPA on a RCA 27V412T
Hello
To unlock the FPA lock of RCA tv, do the following. One amoung the process will surely unlock your RCA. You must have its original remote control handset to do this..
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
May 22, 2011 | Televison & Video
Intermittent audio...picture fine
Does this model have a headphone jack? If so, plug a pair of headphones or external speaker into the jack, turn the volume to an acceptable listening level and see if the problem goes away. If so, the headphone jack may be bad.
Mar 02, 2009 | RCA E09344 Under Counter Kitchen TV 9"...
RCA 27V412T
check your tv's power cable inside the tv. make sure its not frayed. also take the batteries out the remote, it could be turning off the tv.
Dec 29, 2008 | Televison & Video
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
Help my rca model 27v412t tv is going nutts
same here same model-
Been in the shop since Oct 07 and part (keyboard) has not come in as of today 1-09-08 NO Parts being made.
RCA sucks they just want you to have to buy a whole new TV!
Oct 23, 2007 | RCA 27V520T 27" TV
RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Oct 02, 2007 | RCA 27F530T 27" TV
GE 31GT740 31" TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
