Question about Hardware & Accessories
How to set the timer for ingraham heavy-duty 24 hour appliance timer model 12-010
SOURCE: How do you set the Westek Programmable Heavy Duty
http://www.alexfish.com/dload/Westek%20TE05W%20digital%20timer%20manual.pdf
Posted on Nov 01, 2009
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
SOURCE: I have programmed the GE
There are 6 programming buttons on face of 15117 timer.
Download pdf manual
Review of steps:
The AA battery is installed with correct polarity
Timer blinked 12:00
Set clock while holding down clock button
Press PROG to display EVENT1-on (there is a tiny 'on' that shows on display)
>day button selects day, weekday, weekend
>> hour minute buttons to set ON time for EVENT1
>Press PROG so display shows EVENT1-off (ther is a tiny off that shows on display)
>repeat steps above to set OFF time for EVENT1
>Press PROG until EVENT1-on shows in display
>repeat steps to set on-off times for EVENT2
> when finished programming, press CLOCK
> Last step, set mode
MODE is on-off override
MODE is also Automatic or Random
Solution ideas:
Press MODE until Automatic displays)
-Press MODE key to see if manual override works
-Look at digital face (or take photo of it) and compare with Figs shown in manual to see if there is a match
-Check breaker. Check light bulb. Remove timer and see if load works without it. Check that light switch is turned on if plug is controlled by light switch.
-Review programs: Push PROG key to review programs
-Other timers ignore conflicting schedules ... for example EVENT1 says ON at 7 and OFF at 8, but EVENT2 says opposite, or overlaps, then timer ignores programming
-Reset timer and repeat programming: Press CLOCK, MODE PROG to reset timer
-Make a chart of your EVENT1 on-off times, and EVENT2 on-off times, EVENT3-7 on-off times before programming to make sure there are no conflicts.
Posted on Oct 05, 2010
SOURCE: I have a GE heavy duty 24 hour timer model no.
The middle dial is the current time and it works like oldy timer does you set when you want it on then the timer will spin according to the time of day Duhhh
Posted on Dec 18, 2010
  • 5245 Answers
SOURCE: Model dehumidifier DDR2611/4011, how do you set
Boy you know you're in trouble when a web search for your product gives fixya on page 1 google.
There is a product manual for your dehumidifier Sept 2012: but it doesn't say how to set the timer. What a doofus manual.
http://www.danby.com/cms/products/en_manual/Manual_for_DDR26114011_%282%29.pdf
There is a customer care phone number:
http://www.danby.com/en/CA/customer_service
On and OFF are probably manual override, so you can operate unit without timer.
24 hour means a 24-hour military-time clock without am and pm. So 1pm is hour 13, and 8pm is hour 20, and 1am is hour 1, etc.
+/- set the humidity
Best guess for Seting the timer.
Press and release clock (timer) button. You may have to press and hold.
And probably auto start is first thing on menu.
Press + or - button to select start hour from 1 thru 24.
Press clock (timer) button again.
And probably auto stop is next.
Press + or - buttons to select stop hour from 1 thru 24.
Probably you press clock button again to exit timer programming.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Sep 06, 2012
Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I'm using the woods 59200 mechanical timer to automatically open and close a chicken coop door. I can't for the life of me figure out how to set it. Help!
Woods 59202 is 7-day analog VACATION timer and cannot be set.
Vacation timers are preset to turn on-and-off at random times so it looks like somebody is home when you are away.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59202
You might want the 59201 analog timer which can be set for on-off times over 24-hour period. Minimum on-off is 15 minutes.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
If you need a 7-day timer, buy a programmable instead of analog. Wooods 59377 or Intermatic DT630 heavy duty
http://www.amazon.com/Woods-59377-Digital-Appliance-Settings/dp/B000IKQRTU
If you have analog plug-in timer, open following link to see how to set timers:
Jul 05, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I bought timer model #402A. It says 1250 watts tungsten rated. Here is my question: I have a demhumifier that draws 1800 watts-can I use the timer and what does 1250watts tungsten mean? Thank you.
1250 watt tungsten: Tungsten is the tungsten filament in light bulb.
So 402A timer is rated for light bulb only and not dehumidifier motor load.
1800 watt dehumidifier will burn 402A timer, and could start a fire.
I suggest Intermatic heavy-duty appliance timer HB113C:
http://waterheatertimer.org/pdf/070-appliance-timers.pdf
http://www.smarthome.com/25071/Intermatic-HB113C-120V-20A-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Jun 24, 2011 | Tork 402A 24 Hr Mechanical PlugIn Timer ...
Timer won't work
Timer is not identified.
Problem is not clear.
Open following link to narrow down the question, and then add a comment for possible help
May 12, 2011 | Heavy Duty Ge 24 Hr Appliance Timer Nip
On my Woods 24 Hour Mechanical Heavy Duty Timer (59382) there is a slide switch on upper right of face--set to left, switch is adjacent to a circle with a check mark in it; to the right, it is a vertical...
Switch settings are 'Override' and 'Timer'
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
The manual is unclear which is which.
Pull up a few of the segments located around edge of timer dial.
Segments UP for timer off, segments down for timer ON
Plug timer into wall, and plug lamp into timer.
Lamp is ON and bulb is good.
Move timer switch back and forth to see if lamp turns on.
Manually rotate dial to observe if timer segments are correct for ON-OFF.
Unplug timer and set segments, and rotate dial until current time lines up with black triangle.
Plug timer in.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
How do you set a older outdoor noma light timer only 2 buttons
Hi.
See the instructions below in PDF format, instructions are for Noma two buttons heavy duty outdoor timer. Some model may be different in shape:
24-Hour Heavy Duty Outdoor Timer
Regards.
Ginko.
Jul 21, 2010 | Home
I have a GE heavy duty 24 hour timer model no. 15075. I need to know what the dial in the middle needs to be set at and why does it spin? What purpose is the spinning dial serving. If it did nothing I...
Mar 15, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
81 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
