Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Where can I find an Adapter for Bose sounddock to iPad Air?
Old Bose SoundDock for iPod needs adapter to play music off of iPad Air or iPhone 5
  • 20 Answers
SOURCE: Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Posted on Dec 11, 2008
  • 11 Answers
SOURCE: Bose SoundDock burned out two of my iPods - a Nano and a classic.
um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Posted on Oct 05, 2009
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
SOURCE: Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Posted on Mar 10, 2010
  • 51 Answers
SOURCE: Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Posted on Aug 16, 2010
Bose SoundDock will no longer connect to ipod to either play music or charge iphone/ipod devices. Any ideas how to fix or is connector on base damaged and needing repair?
My guess is that the iPod connector in the Sounddock is loose or damaged. You can get a new connector and solder it on yourself (very difficult!) or you could get a replacement PCB at http://www.chargeconverter.com/store/index.php?route=product/category&path=37 which is quite easy to replace (see http://ridax.wordpress.com for description).
Feb 11, 2011 | Bose SoundDock digital music system...
My fully charged 3g Iphone in the Bose Sounddock it keeps poppin
Try putting your iPhone into "Airplaine" mode. It's possible that the radio frequencies from your phone are interfearing with the speakers in your sound dock.
Oct 06, 2009 | Apple Bose SoundDock Series II Digital...
Sep 13, 2009 | Bose SoundDock Portable Music Pack Docking...
SoundDock won't charge newer iPod versions
Unfortunately there is no real fix for this. Apple changed the charging from USB to Firewire, so the old charging methods don't work anymore. I purchased an adapter somewhere on the internet that worked with some devices and not with others, but I can't remember where I got it from.
You will either have to wait for apple to change it, or bose to find a work around, or get a new unit.
Aug 21, 2009 | Bose SoundDock digital music system...
I've lost the power charger for my portable sounddock
If you call bose directly they can sell one to you for around $60
Jul 03, 2009 | Bose SoundDock Digital Music System for...
I have to hold my Ipod forward in the dock to get sound
Not a design issue as far as I've heard. They made the 30-pin din connector a bit 'soft fitting' so that it won't break from pulling out an iPod hundreds of times. The SoundDock II and SoundDock Portable are actually some of the more durable iPod products I've ever seen. The original SD also, but that had a weak power supply. I wouldn't worry about this happening again.
Jun 21, 2009 | Bose SoundDock digital music system...
Won't charge on Bose SoundDock
You're not doing anything wrong. Newer iPods and the iPhone require accessories that were specifically designed for them. For example, the iPod interface in my car will not charge my iPhone, however, I can still play music through it.
The only solution is to: 1: Buy a SoundDock II or 2: Charge your ipod seperately.
Apr 20, 2009 | Apple iPod touch
Jan 14, 2009 | Bose SoundDock digital music system...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
