Question about Tour Trek T112 Golf GPS
Can I re download this thing to make it read right
It worked fine for a few times then it gave out the wrong info
How can I get logged into my Pay Pal Acct. it denies me
maybe it is blocked because you gave the incorrect info try after few hours and try from forgot email or password.
Thanks
Apr 26, 2014 | Computers & Internet
What could be my problem with my 2000 blazer not wanting to crank in right off the bat?
  • So your saying you turn the key to start and nothing 3-4 times? What I am understanding is it don't want to start for a few times.
  • I'd sure like to know what the fuel pressure readings were. There is a pressure test when it is running and when the vehicle is off to make sure the pressure is maintained when the vehicle is turned off. If pressure is not held when the vehicle is turned off then it will do exactly what you are saying it does. Which could be a few things, fuel pump and fuel filter for starters.
  • Possibility of some bad gas of gas with more water than should be in it and the water is freezing just enough to slow the flow of fuel down. I like to use "heat" in the colder months for just this reason.
  • Are we on the same page?
Nov 20, 2011 | 2000 Chevrolet Blazer
Loud tick noise in crankcase.
Thanks for the background info. With all the work that has been done and the good readings I can suggest a few possibilities.
  1. A broken gear tooth, (highly likely if the "tick" is not present in all gears).
  2. Broken gear tooth on the clutch hub, (highly likely if the "tick" is present in all gears).
  3. Wrong heat range on the spark plug causing detonation.
Set the air screw and pilot screw back to factory settings > turn each inward until LIGHTLY seated. Now open each of them one and one-half turns. The stock jetting should be okay.
Nov 10, 2009 | 2005 Suzuki RM-Z 450
Well my Garmin nuvi 1300 was working fine yestarday but now it's saying "No Map Data Available"... What does that mean?
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
Oct 24, 2009 | Garmin nuvi 1300 Car GPS Receiver
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
I can't get my laptop to start every time i try to start it. The start up screen will come up and then sometimes it won't. I don't know what's wrong and why it's not starting correctly.
hi
i have read your problem and its a common one.
you just have to check few things.
1. check if RAM working fine.for this you have to replace the RAM and check it.
2. check your battery.
3. if both these things are working fine there is some problem with your motherboard.
call the customer care and they will replace it for free if its under warranty.
if my solution is helpful rate me well.
thnx
Jul 01, 2009 | Sony VAIO VGN-FS810/W Notebook
Psp won't read disk......loading circle continously shows.
maybe the system is not working right why wont you take it to a mechanic that ccan help you
Jan 09, 2009 | Sony PlayStation Portable (PSP) Console
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Vcr will not work
Try pressing down the vcr or Aux button for a long time. Then try pressing down power button on remote for a long time. Try info or display button for long time. After I fiddled around with these for a long time it worked.
Sep 29, 2007 | RCA VR355 VHS VCR
Tour Trek T112 Golf GPS Logo
Top Tour Trek Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Tour Trek Optic Expert? Answer questions, earn points and help others
