Question about Garden
Installing drive belt 244-5 1991 toro wheel horse tractor
harlan301
  • 205 Answers
SOURCE: belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
Posted on Oct 11, 2009
  • 202 Answers
SOURCE: How do I get instructions on replacing both upper
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Posted on Oct 25, 2009
  • 8404 Answers
SOURCE: NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Posted on Oct 26, 2009
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
SOURCE: need a belt routing diagram for wheel horse raider
have a raider 10 in gravenhurst with a deck sticker that shows the belt routing......if you still need the diagram, let me know
Posted on Jul 29, 2010
Belt diagram install
seems like everyone does but no one knows there model number... darn
Aug 25, 2014 | Toro 3 Standard Blades For Wheel Horse 50"...
I want to purchase a drive belt for wheel horse 16-44 HXLE model 79107 where can I do this?
The belt part number is Toro 93-3884. Just search google for this part number.
They are around $50-60.Also you can purchase from sears . com
or here: http://www.m-and-d.com/TOR-93-3884.html?mv_pc=00015
J
Mar 07, 2011 | Toro Garden
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
Repace large belt on toro riding mowermodel14ap80rp744
Not sure what the problem or question is. How to replace the large belt?
Aug 19, 2010 | Toro 3 Standard Blades For Wheel Horse 50"...
Jul 18, 2010 | Toro Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower drive slips , not belt clutch, assembly. any adjustment? or anyway to fix it?
I hate to tell you this,but not much you can do. I had a toro wheel horse 12.5 hp the drive belt would slip,made it a little better by putting on new belt w/belt dressing,but would still do it especially under load or up hill,or starting in higher gear. Unfortanately,it was one of toros downfalls on a lot of models,and FYI if you think altering the tension pulley to hold the belt back more will solve it,your wrong,all that will do is make you lose use of your clutch.
Aug 08, 2009 | Garden
Garden Logo
302 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
