Question about Dewalt 18 Volt Compact Drill Kit
Dewalt 12v Cordless Drill. Same speed in position 1 or 2 ???
Just open brand new DeWalt 12v Cordless Drill. Model DC742KA. Charged battery. There is no difference in speed on setting 1 or 2 (made sure switch was moved completely in each direction with drill off). Supposed to be 400 rpm vs. 1400 rpm. Did I get a dud? Thanks.
  • Anonymous Mar 30, 2014
    New battery 12volt required
    Brigadier General:
  • 4,090 Answers
Yep and with this model you are not alone! take it back and exchange it make sure it works before you leab]ve the shop
Posted on Jun 23, 2009
Where can I download an owners manual for dewalt dc742ka?
http://powertoolshelp.com/dewalt-dc742ka-cordless-hammer-drill-users-manual
Feb 12, 2015 | Dewalt DC742KA Cordless 12-Volt 3/8-Inch...
Dead DW972 Cordless Drill?
Easiest and safest: take the tool and batteries to nearest shop where they sell Dewalt. Ask the guy to let you use their batteries in your tool and vice versa, your batteries in their tool. DYI procedure:To check batteries: - if you have some multimeter, try to measure voltage and if possible also amps (but only for a fraction of the second, if battery is good, amperes shoudl jump up very quickly) - if you have no multimeter, try to find 12V bulb (check spare bulbs for your car), use wire to connect and it should light up. To check tool: open it up, take some 12V DC source, put wires on contacts inside the handle where battery connects. Pull the trigger and it should work. you can try to put wires directly to contacts on the motor. Follow cables from the switch to motor.
Juraj
May 31, 2010 | Dewalt 12V XRP Battery Pack
My new drill suddenly stopped working even though the battery has been charged OK.
Is it Nano li-ion? have you got another spare battery to double- check?
I experienced the same problem with 18V Dewalt nano li-ion battery. Was fully charged, came to work- Dead!!! I was lucky I had spare one, so then i was ok, but anyways had to buy a new one. Check on these things:
1. Battery is faulty. If u have any chances to ask someone who has the same gun (voltage is very important!!! has to be the same!!!- 12V battery to 12V gun, 14.4 to 14.4, 18 to 18 etc). Put your battery into that other gun. If You find the same problem that means your battery is dead.
2.Gun with battery contacts. If you 100% sure, that batterIES (check 2 batteries, or more) are OK, check bottom contacts where u put battery in, use WD40, or similar to clean them.
3. Least common Dewalt thing (Most common in Panasonic drills) is trigger contacts.
Basically i do not know what model is your dewalt, i was only talking in general, but there are no miracles- stopped working suddenly, and what u describe new, for instance my new drill dw727kd is less than 1 year old, i was too stuppid to open that battery myself to void warranty :(
AAAAHHH!!!!!! One more thing - If you have not tried to open these screws- check your nearest Dewalt authorised repair center- new NANO batteries have 2year warranty!
Apr 24, 2010 | Dewalt 18 Volt Compact Drill Kit
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Dewalt 18v drill dc988 type requires switch
Here is a link for a parts diagram for your model. It has the proper part number that you will need.
Hope this helps.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/dewalt/DC988KA_TYPE_1
Sep 07, 2009 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Delta cordless drill
I would use any 12VDC adapter that has no more than 200mA output. Keep an eye on it. It should be nearly charged within 10 hours. But watch to make sure that niether the battery or the adapter gets too hot. The adapter will get warm, but should never be too warm to touch.
Apr 13, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
New cordless drill won't run with charged batteries
Does the drill do anything? Check in the cavity where the battery goes and make sure there is nothing there to prevent the battery contacts from connecting with switch. I take it the charger indicates the batterys are fully charged. If you cant see anything obvious I would take it back and get a replacement.
Dave
Dec 26, 2008 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt 18 Volt Compact Drill Kit Logo
185 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
