Question about Canon CLC 1150 Color Copier
Z40e 64 bits driver - Canon CLC 1150 Color Copier
  • 87 Answers
2 Suggested Answers
SOURCE: Canon LBP 2900 drivers 64 bit?
Now official drivers from CANON for lpb2900 win7 x64 !
http://fr.software.canon-europe.com/software/0038030.asp?model=
Posted on Mar 10, 2010
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
I have an wireless Epson NX 230 printer 32 bit printer with Win 7 operating sys Emachine 64 bit desktop. Printer driver process says operating system does not support the driver. Test page does not...
Officially MS says it's not support, and Epson does not have an updated driver. Sorry.
If I'm running a 64-bit version of Windows, do I need 64-bit drivers for my devices?
Yes, all hardware devices need 64-bit drivers to work on a 64-bit version of Windows. Drivers designed for 32-bit versions of Windows won't work on computers running 64-bit versions of Windows.
Description: This file contains the Epson Stylus NX230 Printer Driver v6.91. The Epson Status Monitor 3 is incorporated into this driver.
Compatible Systems: Windows 7 32-bit, Windows Vista 32-bit, Windows XP 32-bit
Aug 30, 2012 | E-Machines Computers & Internet
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
My webcam microsoft vx-500 is not working..what will i do to use this webcam ??
You can download the drivers for the webcam from the links mentioned below
Windows XP (32 Bit) LifeCam 3.5 32-bit for Windows XP SP2 or higher (excluding 64-bit)
Windows XP (64 Bit)
LifeCam 2.04 for Windows XP 64-bit
Windows Vista (32 & 64 Bit) LifeCam 3.5 32-bit and 64-bit for Windows Vista
Windows 7 (32 & 64 Bit) LifeCam 3.5 32-bit and 64-bit for Windows 7
Simply download the driver and run the setup it will install your camera, if it does not detect the camera , disconnect the camera and plug in again and it will load the drivers
If you require more assistance regarding this, feel free to contact
regards, BA
Jan 13, 2011 | Microsoft LifeCam VX-1000 Webcam
The issue is many Windows 7 installs are 64 bit, and your software does not work on 64 bit installs. Your drivers lists as 32 bit install even. As this is going to be an issue for many people, is there any...
If you have tried installing the printer driver for 32-bit on your computer, you might want to uninstall it first before installing the Lexmark X6650 driver for 64-bit. Go to Start menu -> Programs -> Lexmark X6600 Series -> Tools -> Uninstall. Reboot pc when prompted.
You can download the Lexmark X6650 driver for Windows 64-bit from the Lexmark website. Go to this link: Lexmark X6650 Driver for 64-bit. This driver applies to Windows 7 (64-bit), Windows Vista (64-bit), Windows XP Professional (64-bit).
Dec 12, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Can I upgrade to 64 bit OS, and install over 4GB of RAM?
http://support.gateway.com/support/drivers/dlcenter.asp
Go to that page and type in your serial number. You need to look and see if there is any drivers for a 64 bit OS. If there is then you know you can install a 64 bit system and get the drivers installed.
If you don't see a 64 bit system for drivers then that means one by one you'll need to manually search thru google for the drivers you have now and see if you can find all of them for any 64 bit system you want to install.
If you can find them then you can still install a 64 bit system.
Dec 17, 2009 | Gateway GT5654 Desktop PC
Windows Vista Ultimate 64-bit
SEARCH THE 64 BIT DRIVERS IN GOOGLE SEARCH.
Sep 09, 2009 | Toshiba Satellite A205-S4617 Notebook
Jul 17, 2009 | Canon LASER SHOT LBP-2900 Printer
Finger Print Reader is not Working on my Acer Aspire 5738 laptop with Windows XP installed on it. kindly
you need to install all the software of this Finger Print Reader and update all the drivers or install the driver.good luck
Jun 15, 2009 | Computers & Internet
Canon CLC 1150 Color Copier Logo
23 people viewed this question
old marine
old marine
