Question about Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Hdmi from dvd direct to tv works(panasonic th-50ph9uk); hdmi from directv direct to tv works; dvd hdmi to av receiver(onkyo) results in sound to speakers but no signal at tv; Dvd and sat are assigned to hdmi inputs on onkyo; hdmi monitor setting is set to yes; attempts to use dvd or sat thru onkyo results in no signal msg on tv; help, Bob
Re: new home theater setup- no signal at tv using onkyo...
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
    Problem Solver:
  • 14 Answers
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Posted on Dec 13, 2007
0 characters
3 Points
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Sony Blue Ray dvd player has stopped working when wired through the Onkyo receiver (works if HDMI wire is connected directly to tv). I have had the setup for 2 years and only use the dvd player a handfull...
Either the 1.8v or 3.3v line to the hdmi board main micro are low. it needs a modifcation. best to have it done at a onkyo approved service center. or take it to radio shack they do onkyo repair.
Dec 30, 2010 | Onkyo TX-SR605 Receiver
I have an Onkyo TX-SR605 AV receiver that just stopped outputing video to my Panasonic projector. I have connected other devices directly to the projector and video is fine, so the problem is not the...
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Nov 27, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
DVD signal received in wrong aspect
Feb 21, 2008 | Onkyo TX-SR605 Receiver
No sound
Go to the OSD setup and for the dvd mode you need to select the appropriate optical output. ie you need to select coaxial for the dvd to the onkyo, by default it is optical.
Feb 05, 2008 | Onkyo TX-SR605 Receiver
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Nov 26, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
4,138 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
