Question about Staples SPL826X (CrossCut) Shredder
Spl-826x Shredder stopped shredding after a while. I t makes a noise but does not move. I cleaned out the paper from the shredder best as I could, still doesnt move. Seems like someting is blocking it, but I cant find what. thanks
  • 3 Answers
SOURCE: My shredder runs but won't grab the paper that I'm
Look down into the slot to see if the teeth are sharp. They should have little J-hook thingys that look like the teeth in your mouth. If it looks ok, give it some food to chew. If it burps it up, throw it away because its a junker and not worth your time.
Good Luck.
Posted on May 12, 2010
SOURCE: Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
Posted on Jul 04, 2010
  • 10865 Answers
SOURCE: Each time I use my staples SPL-616X shredder all
Yes you do need to oil the blades, but it is important to get the right oil. Most stores that sell shredders, like Staples Office Supply, also sell shredder oil. J.
Posted on Aug 01, 2010
SOURCE: HI,I NEED PARTS FOR MY SHREDDER SPL-616X. GEAR
i have the gears - my shredder has broken plastic guides but the gears look fine. i'll mail them to you if you like. Jeff
Posted on Nov 20, 2010
  • 300 Answers
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Posted on Feb 14, 2011
How do I fix a staples spl tmc 10 paper shredder that does not feed?
It may be clogged with shredded paper. With power removed, examine the shredding mechanism and remove any bits you find. You may not be able to remove all of the bits but enough to restore operation.
Oct 09, 2014 | Office Equipment & Supplies
Staples shredder Model: SPL-826X IT SUDDENLY STOPPED GOING FORWARD. ONLY RUNS ON REVERSE. 3/31/11
Your problem is same as mine. I took the shredder apart and notice that the first dented wheel moved by the motor is stripped. I called the product support number and they said the manufacturer do not sale parts for this model. The shredder need to be send to them. At the end, it will probably cost more than buying a new one.
I am trying to find the part on the internet.
Mar 31, 2011 | Office Equipment & Supplies
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
Staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Jun 16, 2009 | Office Equipment & Supplies
When on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
Jun 04, 2009 | Office Equipment & Supplies
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
STAPLES MODEL#SPL-826XSHREDDER
Cleaned the sensors with warm water and Q Tips. Works fine now..
For Staples shredder model #SPL-826X.
Thanks!
Apr 29, 2008 | Achiever SCS-6 Strip-Cut Shredder
Staples SPL826X (CrossCut) Shredder Logo
95 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
