Question about AOC Televison & Video
I ONLY HAVE SOUND WHEN IT IS ON VIDERO 1 - AOC Televison & Video
DVD player only has background sound (songs, sound effects) but no dialogue when people are speaking
On 5:1 surround sound the voices are only directed to the center front speaker. If you do not have one, but your sound system has been set to surround sound (5:1 or 7:1) in its menus, this will happen. Use the menus on your sound system to set it to '2 channel' or 'Stereo' then all of the available sound on the DVD will be sent to the 2 front speakers.
Dec 20, 2013 | Televison & Video
I don't have any sound
Hi Moise,
The problem described could be caused due to two reasons.
1. Sound driver or software is missing
2, Sound card or hardware problem
Check:
1. If the speakers are on and connected correctly to the PC
2. Check with headphones if you have sound
3. Check if the sound settings in mute.
Once the above three checks are done.
1. Try running system restore,to the date when the PC had sound.
2. If the above step doesnot work redo the sound drivers
Download Sound driver
Regards
Mandeep Singh
Oct 02, 2012 | HP Pavilion a305w (DM181AR) PC Desktop
My computer has no sound card installed in it.
Hi
If sound card device is not physically present in your computer system then you need to buy one.
You can look for sound cards at ebay.com
Check also in the BIOS if the audio device is enable.
and also you need a sound driver installed.
Hope this helps. Thanks for using Fixya.
Apr 01, 2010 | Acer Refurbished SYSTEM BOARD 3 PCI 1 ASA...
Cb noise toy
Hi there!!
You need a PC-2 adapter that should have come with your PEAT-REPEAT-1 PP-1. If you already have the PC-2 adapter than you need to plug the mono jack with the 2 blue and 1 black wire into your computer or mp3 player which ever you are getting your sound byte from. Then you need to plug the other end of the jack that has 1 black 1 red and 1 blue wire into the PP-1 then you must turn the power to the radio on. The when you are ready que up your sound byte or what ever you want to record and when ready press the red record button and hold until the sound byte is finished playing then let go of the red button. DO NOT unplug the jack from the PP-1 until you unplug the radio from the power source or you will erase the sound byte. the PP-1 will only hold 20 seconds of recording! Also remember as soon as you plug the jack into the PP-1 it will automatically erase the original sound byte that is in the PP-1 Good luck!! If you need any other help please feel free to E-mail us with any questions that you may have at: bigdscbshop@hughes.net
Dennis
Jun 17, 2009 | Cobra 29 LTD CB Radio
ATHERNET CONNECTION PROBLEM VIDERO CARD PROBLEM
What is the problem? No drivers? Hardware not working?
Mar 18, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Problem about sound
i am using same configuration with 5.1 creative speaker with good sound. in 5.1 sound system there are 2 seperate jack for left and right speaker. you attach one adopter having 2 in and 1 out point.The jack is 'Y' shaped. that will solve ur problem.
Nov 25, 2007 | Intel D915GAV Motherboard
Televison & Video Logo
16 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
