Question about Sewing Machines
How to reulate tension in NECCHI sewing machine
SOURCE: NECCHI 525FA
I have a brand new 525FA. I can try to take a pic of it tomorrow for you. I may have to call my mom to see what part you need a picture of cause I'm not familiar with sewing machine parts at all. But I'll check with her. Or maybe you can take a pick of what you need to see. Then I can look at it, and take a pic of the same thing on mine.
Posted on Jan 14, 2008
SOURCE: Necchi Lydia 3 sewing machine
yahximasiz
Posted on Feb 14, 2008
SOURCE: Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
Posted on Apr 11, 2008
SOURCE: Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: daridoll@yahoo.com. The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Posted on Oct 18, 2008
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
Posted on Jun 01, 2009
Assembling thread tension on Necchi 3101
Oops! All sewing machine diagrams/manuals are available, online. Oddly. From the late 1800's, on.
Jun 15, 2017 | Necchi Sewing Machines
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
Im trying to see if I can fix the upper tension spring on my Necchi 3205fa machine. I think it was stretched out of correct shape.
If the spring doesn't revolve easily while it catches the thread it may be. To see what the shape should look like you can go to Ebay and type in "Necchi 3205fa sewing machine tension control". This should give you some very nice photos. You may even want to purchase one from Ebay and replace the one you are having problems with.
Oct 04, 2016 | Necchi Sewing Machines
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Aug 03, 2014 | Necchi 3537 Mechanical Sewing Machine
How do u thread and set tension on necchi 3205
sewusa.com has some threading diagrams
& you can also see if sewingpartsonline.com or premiersewing.com
have manual for the sewing machine
Mar 15, 2012 | Necchi 4595 Mechanical Sewing Machine
Missing front main tension cover on Necchi 535 F A 180994
Do you mean the Tension adjustment knob? If that is the part you need then try this site: http://vintagesewingmachineparts.com/necchi-535-fa-tension-adjustment-sewing-machine-part-3/ .
There are also several sites that have parts for sewing machines but do not list their complete inventory online. To check if they have your part, e-mail them with a complete description of the part and the model. For example, try http://www.a1sewingmachine.com/parts.html .
I hope this helps.
May 12, 2011 | Sewing Machines
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Mar 14, 2010 | Necchi 4595 Mechanical Sewing Machine
Necchi 511..how do you adjust thread tension on top thread
Before the thread goes though the uptake lever, it goes though the tension (a round "knob" with numbers).
When threading the machine, lift the presser foot. This opens the tension control so the thread can enter and then when the foot is down and you begin to sew, the tension setting will determine how much thread should feed to the needle.
The setting is usually around 4. However, if this is an older machine that has been used a lot and serviced a little, the tension may not work as it should.
Try different settings and if you cannot get a proper stitch, you will need to determine if the machine should be serviced or if you should purchase a new one - service and parts can be 1/2 the price of a decent, new machine.
Feb 28, 2010 | Necchi Sewing Machines
Tension trobleshooting
The proper tension for the 537 is between 4-6. You need to make sure that your presser foot is in the up position before threading.
Jan 20, 2009 | Necchi 3102 Mechanical Sewing Machine
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
