Question about Blueant Supertooth Light Bluetooth Speaker Car Kit
I have Philips fidelio P9 wireless bluetooth speaker...What i could see now is the player will run fine when connected with power suppy, however wont work as wireless bluetooth speaker. Any solution or settings to be changed? It was working fine earlier.
How do I repair the speaker in Philips fidelio P9 P9WHT? Also, could the battery be replaced?
Dear! First to off the battery & then direct on with charger & Check the speakers. If the cracking sound is still then the differnt problem. If nothing then battery problem & replace the battery.
Jan 10, 2015 | Philips Computers & Internet
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
Speaker wont connect to bluetooth
Go to your Bluetooth settings and forget the device. Then re-pair it for a fresh connection. This worked for me
Apr 12, 2014 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
Volume control problems
you must go the MENU, and select speaker, (reset again) and try again.Clean the contacts speaker with contacts cleaner.
Otherwise, the speaker can be faulty.
God bless you
Oct 29, 2013 | Philips Fidelio Ipod / Iphone Desktop...
How do I play music on 2 Philips Fidelio speakers at the same time?
You will have to split the audio cable that is feeding the first one and feed it into the second one. What is the connector that is used to feed the speakers?
Oct 20, 2013 | Philips Ad7000w Fidelio Wireless Soundavia...
I don't know the pin code
Have you tried "1111", "0000" and "1234" ? The default PIN is usually one of those. If it's not try to find some kind of reset button or search for the user manual online.
Oct 17, 2012 | Philips Fidelio Android Docking Speaker -...
How do I view the user manual for my Fidelio wireless speaker? It's such a small disk and doesn't fit in the my apple computer disc slot. Thanks, Jesse
Hello
Send your Email address to me by Fixya comment box. I've the user manual to your Fidelio wirreless speaker. It is in PDF format, and I can't send it to you by this window as it does not allow me to upload PDF fiels by it. I'll send a copy of it to you by return mail. OK.
Jan 18, 2012 | Philips Audio Players & Recorders
Presario 6000 desktop wont power up after transporting. Opened cover & I have loose wires that may be the problem. The loose wires are labeled p9 &p7.
Unfortunately, I do not know P9 and P7. Can you tell me if they are multiple colored wires going into a header/connector? If they are single wires or thin wires you may be able to look at your header of wires which connect the pwr button, rst switch, power led, speaker ( 4 pin thin connector ) if p9 and p7 came off here they could be your power switch.
Apr 11, 2010 | Compaq Presario 5000 PC Desktop
Need Speakers
Bluetooth speakers are no less than any other popular gadgets and they are gaining in success rapidly. These wireless devices are the perfect match between you and your favourite music. Connect this with your smart phone and see how it fills your life with tune. Bluetooth speakers usually come in all shape and size, from potable to wireless and works elegantly keeping that same compatibility and gets connected with almost all kind of phones, whether it's a windows phone or an android and lets you enjoy better music than in-built speaker. PTron Bluetooth speakers will have good bass sound. MOST POPULAR BLUETOOTH SPEAKERS OF 2016 IJ Tech
Apr 17, 2008 | Insignia NS-DV2G MP3 Player
Blueant Supertooth Light Bluetooth Speaker Car Kit Logo
Top Blueant Radio Communications Experts
Michael Vincent Cruz
aliasger yq
Paul Chapman
Paul Chapman
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
