Question about Garden
Missing INstructions for YardWorks water timer CT 59-3213-8
I am unable to locate instructions online and CT does not appear to havethem.
  • Winston Beard
    Winston Beard Jan 24, 2012
    I am trying to program the device so that each of the outlets comes on at a different time. So far, all it seems to be able to do is, turn on all four at the same time at different times of the day or week.
  • Winston Beard
    Winston Beard Jan 08, 2013
    Solution found. If you set multiple outlets to start at the same time, it automatically takes turns in which outlet to turn on starting with outlets 1.
PDF can be found here: http://www.orbitonline.com/lib/media/62032-24ErE_001098.pdf
Posted on Apr 24, 2010
Testimonial: "Git the manual - Thanks! Trouble is, my problem still exists. It seems that the programming does not allow the invidual ports to come on at different times. It seems to be all four or none."
Unable to transmit
The CTCSS codes are probably not set correctly. Baofeng manuals are notoriously hard to read. Look online (Google) alternative programming instructions.
Jun 09, 2013 | Radio Communications
How to set time on Yardworks two zone water timer
Copy following link to access manuals for each brand of water timer on market 2013:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Yardworks does not have website, manuals or warranty claim procedure.
Instead, yardworks repackages other brands of timer, generally water timers, such as orbit or melnor and raindrip. And sometimes repackages other brands of outdoor timers.
Recommend folks stay away from timer-repackagers such as Yardworks, Timex, First Alert, and buy brand names that have clear customer resources.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 05, 2013 | GARDENA Water Timer
Yardworks timer 59-3213-8 not functioning properly
Yardworks is a non-supported brand name that re-packages timers from different manufacturers including Orbit, Melnor, Tork etc.
Copy following link to access sprinkler timer manuals, to help identify product.
Most Yardwork timers are sprinkler, but I have also seen auto-off christmas light timers.
Add a comment and describe timer in detail. Otherwise the only google result for that timer model is fixya, which indicates there are no online resources.
Also check battery ... if timer has battery, it will last about 3 years.
Also do not expose water timers to freezing temperatures.
Most timers last a couple years, and most have 1 year limited warranty against defects in workmanship. Unknown who supplies warranty coverage for Yardworks.
May 03, 2013 | Hardware & Accessories
MANUAL FOR YARDWORKS 59-3213-8
Yardwork timers are made by Melnor
http://www.melnor.com/instructions.php
May 30, 2012 | Hardware & Accessories
I have an Darlac Electronic water timer DW253 but haver mislaid the instructions, where can I download a set?
I cannot find a manual for the Darlac DW253.
It appears the timer is set by moving each selector knob.
http://www.watermate.co.uk/secure/uploads/DW253%20(Small)%20new%20darlac%20pop.jpg
Knob on right is Run Time:
This is how many minutes timer will run each time.
Set run time from 1 minute to 120 minutes.
Knob on right also has ON-OFF override.
Knob on left is Frequency:
This is how frequently the timer will turn ON. Once per hour, once per each 2 hours ... once per 24 hours ... once per 72 hour ... once per week.
So set frequency to 48 and set run time to 20, then every 48 hours the water will turn on for 20 minutes.
To turn timer off, move right knob to OFF.
For continuous watering, turn same knob to ON.
This timer is battery-powered, probably 9 Volt, but maybe AA.
Battery carriage appears to be located on front below the function knobs.
Typically, water timer batteries last one season.
Timer can be connected to household spigot, or connected to any passive water supply for example rain barrel or tank.
Appears to have standard female hose thread on top, or possibly 1/2 pipe thread, and quick connection on bottom.
Plastic water timer exposed to freezing temperatures can crack. Drain water out of timer during cold weather.
Generally if water timer stops working: replace battery, clean battery terminals, and if functionality is not restored, then buy another timer.
Add a comment to fill out the missing details.
Aug 02, 2011 | Woods Inwall 24 Hour Programmable Timer
I have a Yardworks timer 59 7470 0 and I need the instruction manual. Where can I find one?
I cannot find a manual online.
July 2011. Some helpful information can be found by reading Q&A on following link.
http://www.canadiantire.ca/AST/browse/Green/WaterConservation/OutdoorWater/PRDOVR~0597470P/Programmable%252BWater%252BTimer.jsp?locale=en#BVQAWidgetID
The question about instruction manual has 0 responses, but other questions with specific questions have answers.
It looks like you can post a specific question on the link above to piece together instructions.
Jul 14, 2011 | Hardware & Accessories
I need a instruction manual for this item. I am an agent from Overstock.com, and a customer on the line is requesting the instructions, per they were not included in her order. Can you please provide me...
If your customer is missing instructions that should have come with said fixture.. then they need to contact the company for the instructions. ( I only say this because I skimmed over the net for the instructions and was unable to find them online )
Apr 14, 2011 | Computers & Internet
Yardworks 59-3213-8 timer programing
I was just cleaning out a drawer and came across the instructions (two months after I worked through the setup!!). If you would like I can create two .jpg images and send them along. The original printing is pretty small. jbharynuk@gmail.com
Jack
Apr 05, 2009 | Hardware & Accessories
Garden Logo
2,850 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
