Question about Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome...
Morn spout loose at base - Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome...
Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
May 04, 2011 | Moen Monticello Single-Handle Kitchen...
American Standard Jasmine 3821.834 leaking where spout enters base
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
Mar 29, 2011 | American Standard Jasmine 3821.834.295...
I am leaking at the base of the spout. if you put any kind of pressure on it to move it from side to side it leaks. this is a two handle kitchen meon faucet
At the base of the spout it should have an o ring on the spout does it have a nut or cap on the spout that will unscrew to gain access to it. turn water off first.
If it is loose you could try tighting it , but most of the time it would be th e or ring.
May 15, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
How do i remove the spout to replace o rings on 174 spout?
1. you can pull the spout while turining it. If this still does not work, then spray wd40 at the base and try again. Last resort, deep the spout and base unit in 50/50 solution of white vinegar for a day and then try to take it apart.
The base and spout are snugged fit so you will need to apply some pressure to move it.
Mar 21, 2010 | Delta Faucet Delta 174-SSWF Waterfall...
Is their a way to tighten the spout on a Grohe Atrio kitchen/bar faucet? It seems a little loose, but is not leaking
try to tighten collar at base of spout if that dosent work o-ring could be bad
Aug 20, 2009 | Plumbing
Picture location of spout on 88 ford crown 302 fuel inj
the spout connector should be in the harness at the distributor
May 02, 2009 | 1988 Ford Crown Victoria
Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Dec 10, 2008 | Grohe Plumbing
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Twin Lever Kitchen Tap
taggy,
Most of these spouts are held on by a base nut or a top nut. Some have a clip inside which is released from below. It is possible that a small set screw that sits behind the spout should be holding it together. It may be loose. It is also possible that something is broken off as some of these fittings are made of plastic. What to do:
B & Q maintains a customer service operation to assist you. I note that many of the company's units have warranties of 5 years on parts and 2 on labor. I suspect they are your best source of help. You need to find out if something is broken or missing from your current installation. They'll send you a diagram to assist, I suspect.
Oct 01, 2007 | KitchenAid KESC307 Electric Kitchen Range
Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
37 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
