I have 40 inch celcus tv but I've got a thin red line across the screen?
techman
  • 3130 Answers
SOURCE: red lines across screen
wow this set has several problems that cause almost the same symtoms. There is a b+ filter cap off the flyback that supplys screen drive voltage th the crt that gets leaky and gets warm when the sets on. Also theres a resistor that feeds the voltage that gets warm and a cold solder connection appears but its dosent look like a bad solder connection so just resolder it. as a matter of fact most of those largewr resistors in this set causes all sorts of complaints soI resolder most of them just to stop any problems and a friend in the tv business still told me in one case he had an intermittant crt. and x ray protection cuircut problems.. Hope this helps GOOD LUCK
Posted on Mar 31, 2006
techman
  • 3130 Answers
SOURCE: Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
Posted on May 22, 2006
  • 163 Answers
SOURCE: Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Posted on Jan 17, 2008
pishta68
  • 593 Answers
SOURCE: Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Posted on Feb 17, 2008
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
