Question about AEG Dryers
Maytag epic error code f01 - AEG Dryers
    Master:
  • AEG Master
  • 480 Answers
Maytag Epic Gas Dryer
This error code below would be indicated when attempting to start a drying cycle, or after activating the diagnostic test mode.
E1 - flashes if the thermistor is open.
The machine control electronics monitors the exhaust temperture using the thermistor, and cycles the heater relay on and off to maintain desired temperature.
Begin with an empty dryer and a clean lint screen.
  1. Plug in dryer or reconnect power.
  2. Set the following configuration:
Door - must be firmly closed Press CONTROL ON Press CYCLE END SIGNAL (Loud) Press HOLD TO START
3.
If after 60 seconds, E1 or E2 flashes in the display and the dryer shuts off, the thermistor or wire harness is either shorted or open.
  • Unplug dryer or disconnect power
  • Check wire connection at the machine control electronics and thermistor.
  • If wire connections are good, remove the two wires from the thermistor and replace the thermistor.
  • Plug in dryer or reconnect power
NOTE: All thermistor resistance measurements must be made while dryer is unplugged or disconnected from power.
Thermistor resistance: 10 Celsius ----- 19-22 kOhm
16 C ------------ 15-17 kOhm
21 C ------------- 11.5-13.5 kOhm
27 C ------------- 8.5-10.5 kOhm
32 C ------------- 6.8-8.8 kOhm
38 C ------------- 5-7 kOhm
If E1 or E2 doesn't flash in the display, the connections to the thermistor are good. Therefore, check exhaust temperature value at any or all of the temperature levels.
Hold a glass bulb thermometer capable of reading from 32 to 82 Celsius (90-180 F) in the center of the exhaust outlet.
Table below shows correct exhaust temperatures:
maytag epic error code f01 - 24385279-wycorcio5u0xxoh2plbhrodj-5-0.jpg Dado
Posted on Oct 20, 2015
3 Suggested Answers
SOURCE: error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Posted on Jul 12, 2008
SOURCE: error code
my dryer had an f 01 code and would not run . the problem was the thermal unit in the lint or discharge tube . a 5.00 dollar part
Posted on Dec 31, 2011
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
Jan 29, 2015 | Maytag Dryers
Maytag 300 gas dryer F01 error
The error code F01 means the main control is bad.
Aug 24, 2014 | Maytag Dryers
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
MAYTAG EPICZ DRYER ERROR CODE F-01
F01 means the main control board or "micro computer" has detected an internal short. Unfortunately, the only way to correct this issue is to replace the control board itself. It's under the top panel in the front right corner.
Dec 05, 2013 | Dryers
The washer will not start. It reads an error code F01.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Here is the board to order.
Nov 05, 2012 | Maytag Epic Z and Performance Series 2000...
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error code
Jul 12, 2008 | Maytag EPICz Electric Dryer
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
Dryers Logo
152 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
