Question about Dishwashers
Zanussi zdf 211
No water is getting to machine have checked valves are open and water pipes are not blocked any other ideas please
SOURCE: Zanussi Dishwasher DW929 will not take in water
This could be the filter screen on the water inlet valve valve coluged
Posted on Jun 29, 2008
garing
  • 998 Answers
SOURCE: water is not getting into diswasher have checked
check inlet valve and flood control switch
Posted on Aug 10, 2009
  • 154 Answers
SOURCE: My Zanussi DA6152 has stopped taking in water,
Electronically actuated valve that allows water into your machine is most likly:
1. Jammed up with limescale: remove it and rinse with descaler taking care to to get descaler on electrical parts and contacts.
2. Dissconnected or other wiring issue, trace wires bact to controller.
3. Valve fautly: Needs to be replaced, a new valve willcast about 20 and is available from most reputable parts suppliers. Let me know were you are located and I will try and source one for you, but follow steps 1 and 2 before spending the money.
Needless to say the machine should be unplugged before you start working on it and of course dont try any of t he above unless you feel that you can handle it.
Posted on Jun 23, 2010
Testimonial: "I will give this a go , we are in a hard water area, will post outcome thanks"
  • 713 Answers
SOURCE: i have a Zanussi ZDF 231 dishwasher...it keeps
your belt on dish wash is bad replace belt.
Posted on Feb 18, 2011
heatman101
  • 43501 Answers
SOURCE: My zanussi dishwasher, zdf 301
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 05, 2011
I HAVE A ZANUSSI AQUACYCLE WASHING MACHINE ZWF1221W. IT WORKs THROUGH THE WASH BUT JUST BUZZES ON THE RINSE CYCLE. I CAN TURN IT TO SPIN & EMPTY AND THAT WORKS AS WELL.
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
Zanussi built-in oven ZDF 866W socket blows when turned on
sounds as if a wire to the fsd is shorting when oven turned on.
Sep 28, 2009 | Ovens
Water won`t go into machine
if the pipe work has just been fitted check that there is no plug in the fitments, when new plugs are fitted into pipes to protect them sometimes these are not taken out, remove pipes and check in fitments, every thing may seem working but no water is getting in, also check that there is no inline valve in the pipe work "Exsiting pipe work from your mains may have an inline valve" this can be opened and closed with a flat blade ie a normal diner knife will do. you will see a small round head like a screw head in a valve about as big as your thumb.
Aug 16, 2009 | Zanussi FJ1254W Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Problem
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi dishwasher DA 6141 6 years old
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Sep 02, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
