Question about Motorola Mobility RAZR V3c Cellular Phone
Phone has white screen
When the phone is on... the display screen is white. The keyboard is illuminated and still works. I have tried turning the phone off and back on... I have tried turning it off and removing the battery. I tried charging it.
I dont know what else to do except for taking it to Verizon to have them look at it, but I dont have the money for that right now.
  • 4,889 Answers
There is a panel behind the display that is damaged..This problem is common in all phones..You might want to go to a Motorola service center to get it fixed...
Posted on Nov 04, 2007
My screen will not illuminate, but when slide the phone open to expose the keyboard, the keyboard is lit up. I can tell that the phone is on because when I touch the touchscreen, I feel the 'vibrate' of...
hello, before i tell you the problem i have few things to clarify, for your information the screen works with two components the display and the back-light , in order to see what is displayed you need the back-light (this is that you change levels as brightness), the touch screen works separately in top of display
  • You can't see any light in the screen what so ever (low brightness)?, when the phone is slide up and slide down state.
  • Go to a bright-light lamp, bring the phone close to the lamp tilt the phone slightly in either ways and see whether you can see the display (menu or icons)
if you agree with my points, you have dead screen back-light and need to be replaced,
Feb 27, 2011 | Pantech Matrix Cell Phone
My samsung propel will be on but the screen will be completely white. i can turn it off but when it turns back on it is still white. ive tried calling it and it will work but the screen lags and then turns...
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 04, 2010 | Cell Phones
I can turn it on.
try to dial emergency number,,if there is an voice from operator,,it means your phone is working with white screen display,,.you have to replace LCD. but if you dial emergency number,,and there is no voice..it means you need to reprogram your phone
Jun 15, 2010 | Nokia 6125 Cellular Phone
My phone is a samsung u700. its screen is blank and its not displaying anything. backlight on . what could the problem be.only light from the
first remove the battery just 5minites .................then display is out try change dis play .......
May 30, 2009 | Samsung Cell Phones
Sony Erricson z550i Phone display not switching on!!!
in most cases the fibre ribbon gets worn out.
you can try a local cellphone repair shop, or sony service if you can afford it.
the ribbon needs to be replaced.
Jan 15, 2009 | Sony Ericsson Z550i Cellular Phone
Dropped my phone a few too many times. now when i shut the phone, the screen appears "blank" or not illuminated at all. keys are illuminated, but not the screen. still haven't gotten the id...
its the electronic belt that connect the screen to the keyboard is might be cutted or got a lil bit moved from its original place disassemble the phone and see what can u do about that if its cutted buy a new one and solder it its edasy u can
Aug 16, 2008 | Motorola Cell Phones
N95 screen illumination
Did you check thIs?
I.Menu...tools...settings....general..light sensor.....Try to increase the light sensor .
2. change the lcd????
Aug 07, 2008 | Nokia N95 Cellular Phone
Motorola RAZR V3x Whiye screen problem
I have managed to fix the problem by doing a software update.
I stumbled across the solution..........I had the phone connected to the computer when I started it in the 'boot loader' screen as opposed to just turning it on. This time the computer recognised the phone was connected and through the motorola software update program I was able to update the software and the phone now works fine.
BTW I did lose all my address book, messages etc.
To start in the boot loader screen hold down the * + # + pwr keys all at once.
Jul 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
W300i phone displays white screen
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
Jun 16, 2008 | Sony Ericsson W300 Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
