Question about General Electric WBVH5100HWW Front Load Washer
Why won't my GE front load washer model WBVH5100HWW wring water out of clothes regardless of load size
3 Suggested Answers
  • 9 Answers
SOURCE: GE WSSH300G Front Load Washer drains, but
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
Posted on May 27, 2011
SOURCE: I have a GE model #WBVH5100HWW front loading
Crecco610@gmail.com
Posted on Apr 28, 2012
We purchased a Crosley Top loading high capacity washer several months ago. Why are ALL the clothes, regardless of fiber content, wrinkled when they come out of the washer? It does not matter the size
That's a normal result of the spin cycle which wrings the excess moisture out of the fabrics. The wrinkles should disappear, or be significantly reduced, after running them through a clothes dryer, or hanging them properly for line drying.
However, more wrinkles will remain if you allow the damp clothes to remain in the washer too long before drying.
Jan 02, 2015 | Crosley Washing Machines
When finish washing clothes in front loader, all my cloth are hot is tha normal?
check the the fill hoses on the water valve are not reversed. cold to cold and hot to hot.
Feb 09, 2011 | General Electric WBVH5100HWW Front Load...
GE FRONT END WASHER; MODEL # WHDVH626FWW Too often the clothes come out as though they never went through the spin cycle. Setting it to "rinse and spin" rarely helps. Soaking wet clothes you...
I had the same issue and took the bottom panel off below the door and there is a opening where you can unclog the basket and drain. It's about the size of a silver dollar and you turn it (I would suggest having a bucket to catch some of the water that will come out) and then pull the little basket out. Look inside as well and see if there is anything else up in the drain that you might see that is clogging it. Also look around the front of the drum right inside the door and pull the rubber back and make sure your drain holes are not clogged there either. This has helped me each time I have had this problem. I have found pens, pencils, keys, money and other things clogging the basket or drain holes and the water is just not getting totally out of the clothes. Hope this helps.
Jan 11, 2011 | General Electric WBVH5200J Front Load...
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
Not enough water in a front load washer.
Water levels adjust automatically to the size of the load - no guesswork and this conserves water. If this is really a problem she should see if her warranty is still in effect and contact a service tech to check it out. She can also check with Whirlpool customer service - http://whirlpool.custhelp.com/app/answers/list
Jul 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Front loading ge washer model wbvh5100hww
I had to have repairman out. He said it had a filter in front panel that needed to be cleaned. It was full of hard white stuff, like caliche dirt. He noticed I use Arm & Hammer Detergent and he said that was good, but don't use HE detergents because when they mix with city water, it causes an odor in washer. Thanks- Beth
Sep 14, 2008 | LG WM-2277HW Front Load Washer
General Electric WBVH5100HWW Front Load Washer Logo
46 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
