Question about Kenmore Washing Machines
How do I replace the lid latch on my kenmore washing machine 110-28002011?
I need to replace the lid latch on my washing machine. How do I take the top cover off
jsrock516
  • 5911 Answers
SOURCE: Cannot figure how to open top cover
The top of the machine does not open. You have to remove the console to get to the retaining clips that hold the entire case on the frame. If you wish to pursue this follow these steps: 1. Unplug machine. It's best not to have any live voltages when working around the console. 2. Lift console. It will come off in one of two ways depending on what type you have. The end caps on either side of the console are removable on some models by popping them off to the expose a screw on either end. If teh end caps don't come off, you will have a retaining clip holding it in place on each side. With this type, you will need to insert a putty knife (from the FRONT of the console) under each corner and push in to release the retaining clip. 3. Once the console has been lifted from the top, carefully lift up and back to its resting position over the back panel of the machine. Use care when when doing so that you don't break the plastic hinges that hold the console in place. 4. There are two brass-colored clips under the console that you need to remove. Insert a flat screwdriver straight down through the top into a groove in the clip and pry towards the back of the machine. This will release the clip. 5. Once the clips have been removed the entire case comes off as one piece. Make sure you disconnect the lid switch connection on the top of the machine first. This will be a plastic white connector plug. Open lid and place one under the front rim of the case and pull from the back towards you. The case will lift off from the back first and off the frame. 6. Replacing the case is always the tricky part. Looking down through the lid of the case, make sure you place the bottom front lip UNDER the frame first and slowly lower the case on to the frame. There are four cleats the must fit back into slots on the frame before it will seat properly. Also, make sure the back fits back into the casing on both sides or the retaining clips will not go back in properly. Insert the clips into the slot on the back panel first then push down on the opening on top of the washer for them to snap back into place. Now, I don't know if you still want to try to tackle this or not. It does seem like a lot, but it really isn't once you get the procedures down. If it's just a simple matter of cleaning because the washer smells, the odor may be coming from the wash tub itself. Running the machine on empty, with the hottest water cycle you can with a cup of bleach can go a long way towards killing bacteria and mildew. Just another thought to save you a lot of effort. Good luck. I hope this helps you.
Posted on Jul 22, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Nov 02, 2007
jsrock516
  • 5911 Answers
SOURCE: Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Posted on Jun 19, 2008
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
marka19
  • 1430 Answers
SOURCE: Replace "lid switch" on kenmore washer 110-20702-991
Go to www.appliancehelponline.com/servicemanual.html this will walk you thru the lid switch replacement.
Posted on May 12, 2010
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Kenmore top load HE just bought 2yr old after hooked up it worked fine;then loud grinding noise then lid latch light stated flashing only way to det lid open; turn off unplug then plug back in light s
I see a phone call in your near future. Please call a local appliance repair dealer in your area. The HE line of washers were made by whirlpool. kenmore-top-load-just-bought-2yr-old-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Jan 09, 2015 | Kenmore Washing Machines
Latch on top lid won't lock
I believe you will need the lid cover lock latch switch with arm. It may be simple as a bent arm on it not aligning up. with pin
Nov 20, 2014 | Kenmore 24032\24036 Top Load Washer
Kenmore model 70 washer will not empty tub with lid closed.
This is a broken lid switch . You can replace the lid switch or if you need to get it working quickly you can bi pass the switch by unplugging the washer, removing the 2 lid latch screws, pulling out the switch cutting the 2 wires and twist them together with a wire nut.
This is assuming you do not have the self locking lid.But I don't think your model has that function.
May 14, 2011 | Kenmore Washing Machines
The lid is locked on my kenmore oasis washer
Unplug the washer first. How to open the service lid. Latches are approx 4" in from corners in front (where the little crack is below the lid) insert a putty knife, pushing in on the latches and pull up as it gives. Hold onto the side you've released and pop the oter side and lift up.
Now you will be able to see the lid lock; center front from underneath. Use a 1/4" nutdriver and remove the latch.
Now as far as I know, pn:8563937 was replaced with: W10059230 Bought mine from www.midwestapplianceparts.com.
Install is simple; 3 screws (1/4") behind the back panel will allow you to access the plug. Just feed the old one out and the new one in.
Jul 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Washer lid will not open after cycle
suspect bad lid latch there is usually a 4-6 delay after washer stops before latch will release anything much longer proably lid lock ..remove 2 screws bottom front panel front drops and comes off switch is on right remove screw each side of top lift up 2 screws hold latch in place remove wires and screws and replace latch
May 22, 2008 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore issue
get a putty knife and come over about 2inches from the front edge and push in between the top and cabnit should feel a spring retract at the same time your lifting the lid do the otherside and raise the top the push the hook back on the latch and raise the lid then replace the lid lock switch
May 16, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
