Question about Gigabyte Slot 1 GA-6VX Motherboard
Identify mobo from dell model number: MCM
I want a motherboard jumper setting table
You'll need to open the case on your PC; locate the manufacturer name and model number of the motherboard and then use an online search engine by typing in <motherboard> (without the arrows) with the model number. You should be able to find a manual from third party sources or by going to the manufacturer's website to see if the manual is archived.
You can locate the MOBO information at either one of these locations:
  • RAM slots
  • CPU socket
  • or between the PCI slots
MOBO model numbers are usually a collection of numbers and letters between 5 and 7 digits long.
If you have a problem located the model number and manufacturer:
Run the utility; depending on the speed of your processor, it could take seconds or about a minute to pull up the info. <Click> on the mainboard tab, it'll list the manufacturer's name and model number of the MOBO.
A third way to locate MOBO information, Open the <RUN> dialog box from the start menu or by pressing the windows icon key and the letter R simultaneously.
Type <MSinfo32> (without the arrows) and press <enter>
The BIOS ID will be displayed- sometimes manufacturer info and model number will be displayed.
If not, you will be able to determine the BIOS as being either AWARD or AMI (American Megatrends, Inc.); and from there, be able to decode the ID number to a specific manufacturer.
  • AWARD: first five digits indicate the chipset & the following two digits identifies the manufacturer; you'll have to go online and search who that two digit manufacturer is.
  • AMI: the MOBO manufacturer is Identified by the last four digits in the third group of numbers.
Mar 04, 2015 | Acer Veriton M480G-EQ8400C Core 2 Quad...
Please tell me the software which can identify the drivers of motherboard and download them freely?
You don't need software to identify drivers of mobo, just type your product name and model number of your motherboard in your browser.
May 04, 2014 | Computers & Internet
Model number location
Some RAM vendors - such as http://uk.crucial.com/gbr/en - have a 'tool' that will identify your PC ..
Just note down what type of RAM they say is '100% compatible' (you don't have to buy it from them)
Apr 03, 2014 | Dell Computers & Internet
How to update bios on mobo g41m-combo
Upgrading your BIOS
Now lets go through the various procedures needed to update your motherboards BIOS.
First you need to find out if there is a BIOS update available for your motherboard model, and if there is, whether you need it. Before we go searching for that information, you will need to locate your motherboard model number/name.
This can be done by looking at the documentation that came with your system, or even just by opening up the case and looking for the name silk screened onto the motherboard.
If you have a system that was built by a major manufacturer, such as Dell or IBM, look on the manufacturers website under your systems name or number to find updates.
If your computer was assembled by a smaller manufacturer, look for the motherboard manual to identify it. If this fails, use a program like Sisoft's Sandra to identify your motherboard model and manufacturer.
To determine your motherboard make and model through Sandra first down load and install the program. Start up Sandra and double click mainboard information.
This should give you both the manufacturers name, and the model number of your motherboard. Note down that information.
Once you have your motherboard manufacturer name and model, its time to find your motherboard's model, current BIOS revision and look up what newer BIOS revisions are available.
There are two ways to do this, the first through the manufacturers automatic BIOS update software, and the second by searching through the manufacturers website support section.
hope this helps
Aug 10, 2012 | Gigabyte Computers & Internet
How to free download dell p4 mother board drivers
Drivers for motherboards(mobo) are produced by the motherboard manufacturer. Therefore, is your mobo is an Intel or Asus or EVGA for example, you must go to that website to get the drivers. Since your PC came from Dell, the drivers must come for either the Dell website, or from the disc that came with your computer. Dell sends a CD with all the drivers on it when you buy a PC. If you don't have the disc, you will need to get them from the Dell support site. Just search by the name of your computer. It is also a good idea to save all the drivers on a CD for future use.
Mar 01, 2011 | Dell Pentium 4, 2.26 GHz (1W391)
I didn't find drivers for HP P5750-60001.
goi to HP.com and look for the link for downloads. you have to identify what you are looking for but you should be able to download the most current drivers for your device
Feb 15, 2010 | HP P5750-69001 - System Board/P4...
Putting a Dell Dimension 3000 mobo in an aftermarket case and can't identify where to put the power, reset, and led connections. Also, the usb connectors are in in 5 seperate connections instead of the...
i got the problem fixed. Basically what i did, i i took my buil;ding knowledge and an ASUS mobo users manual of all things. hooked the connectors into the corresponding pins with led's on one side and switch controls on the other. it worked! on the USB i just took my time an dput in order +1,-1,+2,-2,gound. all works well.
Jan 02, 2010 | Dell Dimension 3000® Pentium® 4...
How to put a better mother-board into my dell inspiron 1501
Motherboards are model specific because of processor and other differences. There is a model number tag on the motherboard and that is what has to ordered. The service manual link is below that will help in the dis assembly.
http://support.dell.com/support/edocs/systems/ins1501/en/index.htm
Sep 25, 2009 | Dell InspironTM 1501 Notebook
Need the specs and manual for a Foxconn LS-36 mobo dont know what northbridge it has its a478 socket it has three pci slots it was given to me,since I have a spare 478 processor
That mobo appears to come from a dell optiplex 270
http://www.motherboards.org/mobot/
http://forums.techguy.org/hardware/440110-dell-mobo-help.html
Sep 10, 2009 | Computers & Internet
Dell 530 workstation cpu problem
go to gell .com and get the specs for your processor if yours is not compatible you will have to buy one but having the specs you will know which processor to buyy.
Dec 05, 2008 | Dell (2H882) Motherboard
Gigabyte Slot 1 GA-6VX Motherboard Logo
47 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
