Question about Toro LX466 22HP Lawn Tractor 13RT61RH244
Resetting the 50 hour oil change on a LX425 - Toro LX466 22HP Lawn Tractor 13RT61RH244
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
OIL LIGHT CAME ON EXACTLY AT 50 HOURS. i RECENTLY CHANGED THE OIL. Why is oil light on? also oil dip stick reads full.
You may have to reset it.. is this a cub cadet.. if you have the owners manual, it should have the step by step procedure.
Or go to you tube and type in oil light reset for cub cadet or whichever make u have
Nov 08, 2015 | Garden
1110 SECURITY CODE
hi if you forget the security code try default codes like 0000 or 1234 to reset your mobile .if it didnt help you to reset then visit onlinegsmunlock.com here they provide master reset codes for some nokia and alcatel mobile models.
Jul 15, 2012 | Cell Phones
Low on oil ,added oil monitor won t stop blinking is there a reset button disconnected battery still blinking
The hour meter displays the total operating
time.
It will flash CHG OIL (Change Oil) at 50 hour
intervals. The flash duration is one hour
before and one hour after the interval. The
CHG OIL icon will come on and shut off
automatically. The hour meter can not be
manually reset.
Aug 09, 2011 | Husqvarna Zero Turn Mower Z5426
Oil light keeps flashing, Check Oil but the oil gage says that it is full.
The flashing comes on just before the 50 hour mark, then again every 50 hours. It has nothing to do with the actual oil in the engine. It is a reminder only to change the oil. It will then reset after the 50 hour intervals. You dont need to do anything to shut it off.
Hopr this helps
Nov 11, 2010 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet LT1045 oil light is flashing at 50 hours. Changed oil at 45 hours
I am thinking that might be a notice to change the oil, which is only for notification purposes. Check your owners manual. There may be a procedure to reset the timer when you change the oil.
Sep 04, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Riding Lawn Mover with Kohler Engine - oil light stays on.
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Aug 20, 2010 | Cub Cadet Garden
I have a cub cadet lt1550 and the oil light is blinking and a ch6 code is flashing. checked the oil and it is full. just wanted to know if something is wrong or that is a reminder to change oil and if it...
The mower is programmed to remind you to change the oil every 50 hours. It will continue blinking for 2 hours. It will begin blinking again at 100 hours and every 50 hours after that. There is no manual reset.
May 20, 2010 | Briggs & Stratton Garden
How do you reset the change oil light on my RZT 50 mower
It turns off by itself after 2 running hours.From 50-52, 100-102, 150-152, etc...
Mar 14, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Toro LX466 22HP Lawn Tractor 13RT61RH244 Logo
127 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
