Question about Ingersoll Rand Plumbing
Service manual for 15V vacuum pump
Looking for a service and repair manual for a 15V ingersoll-rand vacuum pump
  • 1388 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Posted on Jan 10, 2009
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
  • 98 Answers
SOURCE: Ingersoll Rand DS 35 Service Manual?
Call I.R.
Posted on Jul 21, 2009
  • 41 Answers
SOURCE: I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Posted on Sep 28, 2009
Testimonial: "Cool!!Thanks!I finally got a "page" on pressure switch. Its not in the regular owners manual. It was like pulling teeth,& had to get it from GRAINGER"
  • 54 Answers
SOURCE: I need a service manual for Ingersoll Rand 185cfm
I don't believe you can view these online anywhere. These comprerssors are now owned ny Doosan. You can order a service manual from your Doosan dealer. You will need the product code that located inside the side door of the compressor. Usually near the oil cooler.
Posted on Nov 28, 2009
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
I am looking for a service manual for a INGERSOL RAND P130SD machine
Doosan have now taken over all Ingersoll Rand Portable Air Compressors, if you contact them they are normally very helpful.
Nov 18, 2011 | Ingersoll Air Tools & Compressors
Looking for overhall repair manual for type 30 mo#253 ingersoll rand compressor
To my knowledge IR does not make and overhaul repair manual for the 253. They just have a parts manual showing the parts and part numbers. They do make kits, like a valve kit,overhaul kit,rod kit etc. these kits usually have the part brake down in them.
Jul 21, 2011 | Ingersoll Rand Air Tools & Compressors
I have just bought an old ingersol rand T30 A2955 it has a knocking noise I would like to investigate it further but would like to have a manual handy before I strip it down do you know were to get one...
T30 compressors have changed very little over the years. You can use practically any t30 parts list for an aid in looking at how things line-up.
The link below is pretty much what you will find. Your local ingersol rand repair center will have parts and service manual for your unit. Easy way to look into interior of the pump without tearing many gaskets is to remove cylinder at the base of the pump. Quite heavy so you will need a lift of some sort. Good luck with your repair.
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-749.PDF
May 30, 2011 | Air Tools & Compressors
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Ingrsoll rand air compressor repair manual
Most manuals are available from Ingersoll-Rand, I am not sure they sell a repair manual. however they do have owner and parts manual for the pumps that show breakdown of the pump and can be very handy for reference when working on one. Contact your nearest IR air center and ask for a copy of the manual, and most times they can provide you a copy for little or no cost.
Jan 08, 2010 | Ingersoll Rand Air Compressor Maintenance...
Where may I purchase or download a complte repair manual for the Ingersoll Rand model # 2475N7.5? Thank you in advance, Gary
I would suggest contacting a local Ingersoll-Rand air center, a lot of times they can make you a copy for little or no charge
Dec 28, 2009 | Ingersoll Rand - Rand Type - 30...
Manual
Jan 09, 2009 | Ingersoll Air Tools & Compressors
Plumbing Logo
98 people viewed this question
Top Ingersoll Rand Plumbing Experts
Paul Carew
Tom Chichester
Are you an Ingersoll Rand Plumbing Expert? Answer questions, earn points and help others
