Instruction manual logik slimline flat screen tv mount
Slimline flat screen tv wall mount user guide
Siliconchip
  • 52 Answers
SOURCE: Remove Swivel Base on 42LB1DRA
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Good Luck.
Posted on Jan 05, 2008
SOURCE: instruction manual/user guide
how can start
Posted on Jan 26, 2009
  • 125 Answers
SOURCE: need to take a flat panel tv off the wall mount
Here are a few spots you can try. Underneath, there might be locks that use alan keys. You might need a long alan key depending on how big your TV is. Unscrew these alan keys as much as possible. Some mounts require up to pull the bottom of the TV out and then lift straight up. Try using a flashlight and look all around the TV, Also check the top. Some have clips that need to be pushed to the side. These clips have holes in them and sometime held in with zip ties to keep them locking the TV, You will need to cut the zip ties. Hope this helps...
Posted on Mar 15, 2009
  • 11 Answers
SOURCE: How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Posted on Jan 02, 2010
SOURCE: removal of flat screen pedestal so I can wall mount tv
There a 4 set screws on the back of the TV. There is actually an arrow pointing down to show you what direction the pedestal. Remove thesze screws and the pedestal comes right off.
Posted on Dec 27, 2010
Seeking Owner's manual
have you looked in the owner's manual ?
Support LED TV UN40H5203AF Samsung TVs
don't know if this the right one for your set, I think the 40" series all have the same manual. I couldn't download it myself. Also on that webpage you can 'chat' to a Samsung rep. who should be able to give you better directions to the correct instructions
15.January.2016
Jan 15, 2016 | Universal 40-42 Inch Flat Screen Panel...
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
I'm trying to hang my tv "Lcd Thomson 32E92NH22"
in the manual there is now screw size specified. there is only a notice about VESA mounts.
here is a link to the manual, so you can have a look yourself: http://safemanuals.com/user-guide-instructions-owner-manual/THOMSON/32LB130S5-_E
greets, b.
Mar 01, 2011 | Thomson 32LB130S5 32 in. LCD TV
The plastic stand that is attached to the TV bottom, how do I remove it so I can mount the TV on the wall?
Click Sony Support link to download instruction manual about how to remove stand from KDL-V40XBR1 tv.
Hope this will help you.
Thanks.
Jan 28, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
