Question about Daisy Model Red Rider Rifle 1938 BB Guns Model Red Rider Rifle 1
Why is co 2 200 leaking air - Daisy Model Red Rider Rifle 1938 BB Guns Model Red Rider Rifle 1
    Top Expert:
  • Daisy Master
  • 51,143 Answers
No doubt the seal got damaged .
Posted on Feb 02, 2015
1984 toyota truck has high CO
here are the causes of high CO:
Defective Oxygen Sensor
- Inoperative Air Injection System (if equipped)
- Leaking or defective Fuel Injectors
- Restricted air filter (especially if high CO is present only at high RPM)
- Vacuum leaks resulting in improper MAP sensor operation
- Defective air mass or air flow sensor
- Malfunctioning fuel evaporation system or purge valve
- Defective Catalytic Converter
- Defective thermostat (cooling system), thermostat stuck open
- Oil contaminated with fuel, excessive miles between oil changes
Since this is not injected, you can rule that out.
Feb 09, 2013 | Lanier UNKNOWN
2004 Petrol/Gas Toyota Prado with overheating problems
We do not have this model in the US so have no data on it. Sorry
Jun 15, 2012 | Cars & Trucks
Fridgerator wont blow cold air
You wither have a bad compressor, or there is a leak in your cooling system leaking refridgerant. Have it checked by an appliance service co.
Apr 30, 2012 | Cars & Trucks
When the hot water heater is running water leaks from the chimney. the pipe from the heater to the chimney is dry upon removal. about 3 gals. of water leaks from the chimney with two showers.
If I understand correctly, your Bock gas water heater vent is causing water to leak down into chimney.
This is a very serious concern
Water leaking from water heater flue indicates improper venting.
The hot air gasses from water heater combustion contain water vapor, but the gas should vent out of house before condensate forms on pipes.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#flue
The problem might be caused by a power vented furnace that pushes vent air from furnace down into flue pipe for water heater. As a result, the water heater doesn't vent properly.
There could also be a clog.
Light a match under water heater draft hood and see if smoke from match travels instantly upward.
There are two major concerns.
1) If vent is not working, it means that odorless CO gas is entering home instead of venting outdoors.
CO carbon monoxide is deadly poison.
http://en.wikipedia.org/wiki/CO_poisoning
You can buy CO detector after vent is repaired.
2) Water condensate will eventually rust away vent pipes because of acidic content of the combustion vapor. It can be expensive to replace pipes, and pipes with holes pose risk of CO poisoning.
My suggestion is call a qualified plumber ASAP and explain what you observe.
Plumber will want to inspect the vent pipes, and may want to extend water heater vent pipe up further inside chimney so furnace is not pushing air back into water heater vent.
Plumber may also find blockage somewhere in the vent stack or chimney.
Also post on a professional water heater forum like the Tank to double check anything the plumber says to you. These are the pros.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Dec 25, 2010 | RTO Bock Water Heaters 32E 32 gal 104,000...
Rattle when accelerating
had the same issue, had someone look and it seems the noise was caused by heat shield being loose covering exhaust system. Have that checked out.
Jan 15, 2009 | 2005 Nissan Pathfinder
Idle raises to 2500 rpm when car is very hot
Check the inlet air temp sensor. It should be located near the airbox but before the throttle body. This unit does not show in code. It registors the outside air temp and adjusts throttle and fuel mixture to match. If the sensor id faulty it will show as being cold and set the throttle for cold starting and running. Check manual or Autozone for multimeter ohms check on this unit.
don
Sep 30, 2008 | 2003 Ford ZX2
Need help!
Sounds like a vacuum leak somewhere
Aug 16, 2008 | 1995 Suzuki Sidekick
Daisy Model Red Rider Rifle 1938 BB Guns Model Red Rider Rifle 1 Logo
107 people viewed this question
Top Daisy Optics Experts
BJ Russell
Andrew Taylor
Andrew Taylor
Are you a Daisy Optic Expert? Answer questions, earn points and help others
