Question about Hunter 52" Ceiling Fan With Light And Remote Control
WIRE A CASABLANKA FAN BY PASSING REMOTE CONTROL MOTER #K55AMBHT
I have a ceiling light that does not have a switch anywhere. Can a hunter 27185 remote control be used to control the ceiling light fixture only. There is no fan in this scenario. How should it be wired?...
Connect the lamp output wire of the receiver to the hot wire of the fixture, and the incoming hot wire to the hot input of the receiver. Be sure to insulate the fan output wire(s) so nothing nasty happens if someone presses the fan on button.
Check the remote control manual to see if you can use compact fluorescent bulbs. You probably cannot if this is a dimming lamp control; most CF bulbs flicker wildly if used with dimmers, and will not last long.
You can also buy remote lamp-only switches.
Sep 22, 2010 | Hunter 27185 Remote Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
FAN BLOWER (FOR A/C AND HEAT) ONLY BLOWS ON THE HIGHEST SETTING. IS THERE A FAN SPEED CONTROL OR RELAY THAT CAN BE REPLACED, OR IS IT SOMETHING ELSE?
Hello leebarker
The blower moter switch or the blower moter controler can cause this
problem. Remove the plug from the switch, use a 12v test light to locate
the 12v power wire in the plug. Next with a small jumper wire bring power from the 12v contact to the low and medium speed contacts on
the plug if the blower changes speed replace the switch if it still only
has high replace the controler. The blower controler is located on the
passenger side end of the heat-a/c box near the blower moter.
By the way the key must be in the on position for this test.
I hope this helps. Good luck.
Jul 10, 2010 | 2002 Jeep Grand Cherokee
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
