Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
WS-65869 Turns off automatically after about 2 seconds
When you power the TV on, it stays on for about 2 seconds, then automatically shuts off. I tried using a pin and hitting the reset button, as well as disconnecting the power to the TV. In both cases, the green light flashes for about 1 min. then shuts off. Neither case seems to be much help. Do you have any ideas for me ??
  • raulcastroa May 11, 2010
    Did you ever got any help on this I have the same problem
I have the same exact problem, did you guys got any help?
Posted on Nov 29, 2010
After the green blinking light turns off I can not turn on the power ,I push power the green light turns on for about 2 seconds then turns off
Hi Robert,
This is an indication of faulty bulb and/or its power supply section. Once the processor sense failure on the bulb the unit will automatically shuts off and led will flash an error code. Also, you should check its power supply first before replacing the bulb because the same symptom will be encountered if there was faulty in that area. Check open fuse/fusible resistor in line with the supply, bad solder joints and leaky capacitor.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 13, 2011 | Mitsubishi WS-65869 65" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
My tv will not turn on
Incorrect power supply voltages present...accordianman
Feb 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitssuisbihi ws 65869
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Aug 25, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitshibishi 65 " HDTV
Check 5A micro fuses F9A04 and F9A05 - If one or both are open,change the single convergence IC part# STK393-110.
Aug 22, 2007 | Mitsubishi WS-65869 65" Rear Projection...
TV will not turn on
Apr 09, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Problem with WS-65869
One of the 3 CRT's being bad is a possibility but more than that at one time no. If the picture doesn't come on at all or any menus showing up the most likely you have a power supply or high voltage issue. Have a technician look at it for the best diagnosis.
Apr 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
