Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Connecting a FLat Panel TV to me PC
What type of cable do I need and where does it plug into the PC?
  • 286 Answers
Check your owners manual.
You need either a 15 pin VGA cable or a DVI (Digital Video In) cable.
Look at the back. If you have a small D-Type connector with 3 rows of 5 holes you need the VGA cable.
Of you have a rectangular connector with rows of angular holes and two slotted holes on one side then you need a DVI connector.
If you're current monitor cable is removable from your monitor you can likely use it.
Posted on Feb 14, 2008
I moved the Mintek Tv from my bedroom to the living room, the tv cable cord will not screw into the Tv, I was told that I need a adapter, coax to av-rca, is this correct? What do you think?
Not sure due to lack of information to go on
I. think you need a tv coaxial female to f plug male adapter
really depends on the TV cable cord what is the gender of the end of the cable if it is coaxial male then the adapter needs a female coxial
if the tv has a female socket hole then the f type part of adapter needs to be a male.
The tv manual may shed some more info on the type of RF antenna coaxial connector. it uses.
RCA can be confused as av is to do with with hooking up a Video recorder with Video output being the yellow plug and audio with Red and white plugs.
I think you need a RF coaxial adapter rather than AV RCA if you are connecting tv to a tv antenna or tv antenna splitter device.
there is a RCA standard that has adapter like below link
again gender types are needed to be considered before deciding if correct type of adapter..
You could research the rca rf standard to see if it is used in your country. My country uses Pal coaxial standard.
May 03, 2015 | Mintek Televison & Video
How to connect DvD play?
It depends on the type of TV you're connecting it to.Please be more specify the models.Preferably,use Component Cable and left/right audio cable,next use a composite cable that has yellow video,white for left audio and red plug for right audio.The plugs and jacks are colour coded,so just match them and you're all set.
If it's a 1080 upconverting dvd player with hdmi and your tv is an HDTV with HDMI,use that.
Nov 23, 2012 | Hisense Televison & Video
Connecting PC to tv
Config you PC for the Video out put.
Oct 03, 2012 | Hyundai HLT-3272 32 in. LCD Television
Westinghouse 32' flat screen tv wont work with cox cable receiver
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Has sound but no picture
check your input cables leading into your tv and the device you are connecting have been plugged into the correct inputs/ports on both your tv and the device attached to the tv that you are trying to view.
you may have installed the wrong cable to the wrong port or wrong port type. most cable & ports are color coded, so watch that you are plugging the cables into the correct ports.
tv's tend to have more then one type of connection and the cables will fit into either type, but you have to make sure you are using the same type of port as your device is (look for the set of plugs that are the same color/type as what your device has.
Jul 02, 2011 | Hitachi 50PD9800 50 in. Plasma Television
Connecting my computer and tv with hdmi cable
Turn both off and on again, while plugged in - the computer should recognize the new connection
Jul 03, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
Connecting wire between pc to tv
Depending on what type of TV you have, connecting your PC to your TV shouldn't be very expensive. Most newer models of TVs come with a VGA input.
Your computer has a cable to go to the computer screen, this cable is known a s a VGA cable, it looks like this:
Your TV might have a VGA input which looks like this:
All you have to do is unplug your VGA cable from your computer screen and plug it in to your TV so your cable will go fro your computer to your TV instead of your computer to your screen.
If your TV doesn't have a VGA input, it will have an RCA input which looks like this:
You can buy a VGA to RCA cable which will allow you to connect your computer to your TV which looks like this:
You can buy a VGA cable here:Click Here
You can buy a VGA to RCA cable here: Click Here
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
Feb 19, 2010 | LG 22LH20 LCD TV
Connecting to a computer
If you don't have a VGA input on your TV, you need to convert the signal using a device like this:
PC to TV Converter
Jun 05, 2008 | Polaroid FLM-2011 Television
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
50 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
