SOURCE: mfc 9420 brother
Same problem, went through the entire printer, removed all parts and it started working. Next day the same message
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
SOURCE: replaced mainboard on brother mfc-9420 -
The setup country code for South Africa should be xx24 (which is changed in Maintenance 74). It's possible that you cannot change to this code, as region specific machines not always can change to codes out of their regions (i.e. Pan Nordic, Benelux, East Europe etc).
SOURCE: brother MFC 9420 says:reinstall tray#1, never goes to ready.
Here is a solution I found posted by Razor. (It turns out my engine controller board is bad.) Good luck with yours.
On your control panel, press "menu/set" "7" then "2". if your page count shows 288,888, you have a bad engine controller board. anything other than that count, most likely is a damaged paper cassette. there is a tab on front left side that is probably worn or broke off.
SOURCE: how do i reset the life of the fuser on the mfc
Actually the Replace Fuser message on these specific models sometime fail to reset after you replace the part.
If this happens:
Press Menu 6,3 and then select option 4 (Fuser)
Press okay
Press Stop/Exit
If you haven't replaced the unit then you should try that first.
Additionally If you are an unhelpful troll, don't post your ad-homonym attack as a solution.
Just scroll down the page and u find 3 download links :
and try to install driver just from device menager
