What projector lamp goes with the 52 inch panasonic lcd lsgh0056
4 Suggested Answers
  • 86 Answers
SOURCE: Ihad install a new lamp in my LCD panasonic 52
First if you have no power or picture ,and you did the install . You should go back and check all connections. Also did you unplug power and dissconnect from cable as either could cause malfunction. Also if you touch the glass wipe clean with alcohol .
Posted on Mar 12, 2010
SOURCE: where is my lcd lamp located on my panasonic rear
How to change lamp on PT52LCX15K
Turn TV off and wait for the red light to stop blinking,then unplug it from the wall. IMPORTANT: Wait for a least a hour after turning off your TVfor the lamp to cool off. It is veryhot On a Panasonic PT52LCX15K the lamp is located under thefront panel that covers the speakers.
  1. Remove the front panel. Just grab it on both side and pull gently.
  1. TO THE RIGHT OF THE LEFT SPEAKER you will see a round locking knob on the lamp cover. Turn the knob to the left and remove the cover.
  1. Inside you will see a case with a handle on it. Pull it out and you will see the lamp assembly
  1. Remove the two screws holding the lamp assemble and remove. Use the handle.
Putting it back in just do everything in reverse. You will have to reset the lamp meter yourself.To reset the lamp hour meter:
Hold down the volume button on the TV and at the same timepress and hold the PIP (picture in picture) button on the remote. Watch the screen and you will see when it is complete. It only takes a few seconds.
Posted on Sep 17, 2010
lbrown1806
  • 488 Answers
SOURCE: how do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Posted on Apr 12, 2012
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Ihad install a new lamp in my LCD panasonic 52" but it is still not working, what can I do?
Mar 09, 2010 | Panasonic 2 Projector Lamp
LG 52 Inch Rear Projector TV - switches itself off
LAMP pull it out and see if it looks busted on the inside.
Dec 21, 2009 | LG RU-52SZ51D 52" Rear Projection...
Last night, a message started appearing saying the lamp needed to be replaced on our Panasonic LCD TV. What is this and is it something we have to do? I think it's the Panasonic PT-AX200 LCD Projector, but...
the lamp is good for about 2000 hours. after this, the lamp may still work, but not as well or for very much longer. after you replace the lamp, you have to reset the lamp timer (in the menu settings).
Aug 10, 2009 | Panasonic PT-AX200 LCD Projector
Yellowing spots on 52 inch LCD Mitsubishi display
have the store fix it you need a tech that has the right equipment to fix that. Since you say you replaced the lamp I assume you mean a LCD micro projector not an LCD Flat panel. There is a piece of equipment that a tech should have that can be plugged into the TVs circuit board and it can fix the spots with an electric pulse. I have seen in done on micro projectors in the store that i work by our techs. So my advise is have the store fix it before your warranty runs out.
Mar 24, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
My Panasonic LCD projector has a blinking LAMP light, how do I fix it? Model # PT-AE700U, hasn't ever had an issue before..
Replace the lamp and rest the hours. This procedure is covered in your owner's manual on page 52... If you don't have the manual click here: http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Dec 04, 2008 | Televison & Video
PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
jasbo
jasbo
