Question about Singer 57815 Mechanical Sewing Machine
How do you put bobbin case in
The bobbin case popped out of machine . I can't get it to flush with plate. It makes a popping sound
kent581
  • 87 Answers
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Posted on Mar 18, 2009
  • 3 Answers
SOURCE: bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Posted on Jun 20, 2009
  • 980 Answers
SOURCE: APOLLO Bobbin Case - replacement/installation
The silver plate should be on top.
Posted on Jan 01, 2010
Testimonial: "Thank you very much for your advice, I had initially placed it on top and it seemed to work but I wasn't 100% sure, now I am, thank you once again."
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
  • 1116 Answers
SOURCE: Bobbin case keeps popping out of my CE-100 Futura.
Raise the needle to it's highest position and the case should go right into the shuttle.
Refer to the maintenance section of the manual for your machine.
If you do not have a manual, you can get one at the Brother website.
Posted on Apr 01, 2010
Hallo Rhonda
Pls chk your bobbin locking at fixing shaft grew or not. on bobbin a sliding locking plate locks at shaft. while keeping in case chk that is loked by pulling. if it dosent lock , change bobbin with spare one.
Jul 16, 2014 | White Sewing 2037 Mechanical Sewing...
Hi. I have a Juki DDL-5550N. While I was sewing the needle broke so I replaced it then the was a noise like a click and the the froze. ..I cannot move the wheel that moves the needle holder at all, it's...
first did you find the broken needle. A lot of times the part that broke off will fall down in your hook assembly and lock up the machine. That is what it sounds like. If its the drop in bobbin the take your needle plate off and check your bobbin case. It probably has popped out of where it should be. Take it out make sure there is nothing in the hook area and put the bobbin case back in. That should fix your probalem
Apr 29, 2014 | Sewing Machines
Why does the bobbin case on my Baby Lock Elegante seize and pop up?
Sounds like you have a burr. Examine both the case and the bobbins for burrs. (use your fingernail... feel for thing that catch your nail) File them off carefully with fine grit sand paper.
Burrs can happen when a needle bends and breaks... stabbing the wrong area... sometimes it's manufacturer defect in the plastic bobbins.
Nov 17, 2012 | Sewing Machines
Needle plate on Pfaff 1471 - removed to clean, when I try to put it back on it keeps popping back up. Is there supposed to be a
check to make sure the bobbin is seated correctly in the bobbin case & then try the bobbin cover, it's suppose to click or snap in
Mar 30, 2012 | PfaFF Sewing Machines
Bobbin problems
Definitely needs retiming, I can attach instructions if you email me. drivewithken@blueyonder.co.uk
Jun 26, 2010 | Singer 2639
The bobbin case keeps sliding and popping out in the middle of sewing something. I'm having to unscrew the bobbin cover plate and put it back in on an average of four times each time I sew.
This is a real bummer! check to be sure you have inserted the bobbin case fully and correctly. Make sure there is no lint hiding behind the bobbin case.
May 31, 2010 | Singer 2639
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
I have a Singer Merritt 4530 and the black bobbin holder thingy came out. How do I get it back in without bending it. Do I need to remove the plate with a screwdriver?
make sure the small silver clip is pushed to the left, pop the bobbin case and. make sure the needle is all the way up first, put the clip over the bobbin case.
Sep 10, 2009 | Singer Sewing Machines
Machine making a noise.
you may have put the bobbin in wrong so when runnng it pul on the thread which pops the bobbin,
check under the boobin case make sure it clear of dirt and thread, also the piece under the bobbin case may also have been push out of place make sur it is in correct.
Aug 26, 2009 | Singer Quantum 7350 Mechanical Sewing...
Singer 57815 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
