Question about Peavey PV-3800 2-Channel Amplifier
What happens when the amp looks like its going to turn on but turns on the fans and a red light.
  • 88 Answers
Amplifier is going into protect mode. Suggest you get it checked out by someone familiar with Peavey amplification
Posted on Nov 12, 2014
How do I install a 4 wired (blue, white, light blue & green ground ceiling fan w/lights to a two (2) wired (red & white) outlet in the ceiling?
basically you have 1 nuetral (wht) and a common(usually black, but in your case, RED). What you should do, is if you have a meter.? Set it for AC volts & check your power there and confirm that your white is neutral (use black or neg side, lead wire from meter and hold it on white) & (use the red or pos.side, lead wire from your meter and hold it to the red wire) being careful. always assume the electrical wires you are dealing with are hot and they can seriously hurt you. If you are in doubt, please, hire an electrician for this. if you are comfortable, then continue and have someone turn the switch on for you to confirm your power . Your meter should read 119-120 volts. somewhere in that range. if it reads -110 to -120 (neg. reading. it means your wires are crossed. and wht is pos or common and red is neutral rare but could happen.) so moving forward. say white is neutral & red is common everything check. then connect wht to wht, grn is ground so connect all grds together and connect those to a screw at the box or canopy bracket if its a clg fan. then connect the remaining blue wires to the red wire. this will power both the fan and the lights form the one switch. the only way to separate them is with the pull chain(s) coming down from 1 the fan motor & 2 the lights. Now, you can separate them and have independent control over them if you were to go with a wireless remote. they make one specifically designed for your situation. (just a thought) I hope this answers your question with a whole lot more questions. Let me know, ill be happy to answer them. good luck & BE CAREFUL!!
Jul 01, 2015 | Dryers
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
My ps3 wheni go to turn it on n press the button the lite goesfrm green rite back to red n wont turn on
This fix works for some models, so if it does not work for you please tell me your model number
Look at the bottom. This is what it looks like:
SONY
PLAYSTATION 3
CECH-*** = Your model number
SONY COMPUTER ENTERTAINMENT INC.
MADE IN XXXXX
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it, it will beep
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and blink a red light.
When this happens, turn the main switch off and on then turn it on normally.
Let me know how this goes!!
P.S. It will not harm your ps3, It's testing the cooling fan.
Nov 28, 2011 | Sony Playstation 3 (PS3) Console
Fan just quit working one day. Nothing happens when I turn the light switches on and off.
Is it powered thru a light switch? Sometimes those do just quit. You can remove the old switch & replace it. Go to Lowe's/Home Depot, the switch itself is fairly inexpensive (probably less than $5). Remember to turn off the breaker to that room/switch before you do anything. The installation itself is simple - just wire + to + and ground it. Did you notice any kind of noise/smell before it stopped working? If the motor is burnt out - just replace the whole fan (unless you feel like tinkering with breaking it down & finding a replacement motor). Sometimes the lite switch on the fan itself will go out - parts for that can be found at about any larger hardware store, but sometimes that's not an easy repair (depends on what type of lite kit is on the fan). However, if that were the problem -it would not cause the blades not to turn, it would only keep the lights from coming on. Try replacing the light switch that turns the fan on/off first (the one on the wall, not on the fan itself) - hopefully that'll solve it for you. Good Luck.
Jul 13, 2011 | Hunter Fan 21623 Concert Breeze Ceiling...
I have a acer aspire T135 and when I turn it on to boot I get the red and green light with a loud whirring noise from the cpu anyone know what is happening and how can i fix it please
sounds like the cpu fan and that would also explane the green then red lights also open the tower access panel but first unplug the unit,wait 30 secounds or so plug the tower back in then look at the fan sitting on the motherboard or main processer see if it turns on and make sure it keeps running they tend to start then if there is a problem they eigther don't turn on at all or turn off a few secounds later Im thinking later would explane the lights
Dec 17, 2010 | Acer Aspire T135 PC Desktop
Amp won't turn on, red light on amp is flashing
DID THIS JUST HAPPEN ALL AT ONCE ? OR DID IT GRADUALLY HAPPEN? CHECK GROUND FROM AMP , INSTALL ONE FARAD CAP . STOCK RADIO ISNT REALLY HELPING , MOST AMPS OF TODAY TAKE A HIGHER SIGNAL FROM HEAD UNIT . ADD ONE FARAD CAP AND SEE
Jan 17, 2010 | Car Audio & Video
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
Amp runs but then will just turn off and red light comes on
you need to get a fan for it because it does not come wit one and when you get the fan you have to hook it up from the inside by taking the torture tested/bolt sign off and look for a small white pug to attach it to
Dec 08, 2006 | Lightning Audio Bolt B2.150.2 Car Audio...
Peavey PV-3800 2-Channel Amplifier Logo
89 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
