Question about Black & Decker BL1900R Blender
Stopped working plugged in wall don't work
Black and decker blender stop working no power
If you are certain the outlet on the wall is "hot", then the problem will be in the plug, the cord, the switch, or the motor.
An appliance person can tell you what the problem is, or, if you choose to fix it yourself, you will need to take it all apart and test it with an electric meter.
Know that you may not be able to find a place that will sell you any parts, they may not be available.
God bless your efforts.
Nov 21, 2017 | Blenders
My 6700 0ster blender won't come on when power button is pressed. What do I need to do?
check the wall plug to prove there is power with an appliance known to work. If still inoperative, return for service or buy a new one.
6700 0ster blender Google Search
Feb 10, 2017 | Blenders
I replaced the immersion heater in my hot water tank, like for like , replicating the electrical connections as well. It does not work. There does not seem to be any power coming into the heater. The
Learn in 2 minutes to use a multimeter to measure resistence ohm and/or continuity,buy a cheap one at a local store if u don,t have and measure the integrity of the element,ceck the voltage on wiring and/plug,if no power comes in, it will not work !?!
Regards
Oct 28, 2014 | Blenders
My Blender is not working.I can presume that it's motor have som problem...In this morning I used this blender and suddenly stopped to work....
not sure what that could be,if you have no power at all,i would first check and make sure the fuse is ok.
or try plugging it in another outlet to to make sure its not the outlet thats faulty.
Oct 26, 2017 | Brentwood Blenders
Plugged 120V appliance into 220V socket
Its dead, and whatever you do, DO NOT plug it into any power again, it could cause a fire so fast that you would be in mortal danger.
Most of the world uses 'real' levels of power, your american appliances cannot handle it.
Dec 19, 2013 | Blenders
Philips refuses to replace faulty blender HR 2021
They have no obligation, the shop has an obligation to repair or replace but not to refund under UK Trading Standards Rules.
Jun 16, 2017 | Philips Blender HR-2021 1.75L
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
Blender died while in use n hasnt worked ever since
As long as you know the plug still had power. Make sure it wasn't a GFI that was tripped. Something inside the unit must have either lost contact or burned up. Did you smell anything burning electrically?
Aug 03, 2009 | Black & Decker Blenders
Wolfgang puck bistro blender won't turn on, need
I had the same problem. There's a little button on top of the base that is supposed to get pushed in by a male-type piece on the bottom of the pitcher. I broke a match stick and duck taped it so that it pushed in the button on the base - Voila! it works!
Jul 06, 2009 | Blenders
Vitamx blender works at low speed, but blade stops moving at higher speeds.
Did you ever find a way to fix your blender? I have the same problem, I'm sure it's a loose wire but can't figure out how to get to the wires.
Aug 29, 2008 | Juicers
Black & Decker BL1900R Blender Logo
47 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
