Question about Broan-NuTone WS330 Kitchen Hood
Where to find how to replace nutone premier np52000 fuse?
Manual does not provide details as to how to get to the fuse box on the hood. Where is it and how do I replace the fuse without tearing it up?
2 Suggested Answers
  • 34763 Answers
SOURCE: need light cover nutone whispaire 36'' stainless hood aprox 20007
You might be able to get the part from an appliance parts supplier
Posted on Mar 21, 2013
Premier kitchen range
I dont think they have fuse ...you will have to disconnect from your switch panel
May 10, 2014 | Broan-NuTone Kitchen Ranges
How to do you wire 2 separate exhaust fans to a double single pole switch with a 20amp breaker problem
Your statement is a bit off the wall
Do you have two single pole switches or two double pole switches
You would normally provide a Live, Neutral and Earth to each fan via a switched , double pole, fused spur box .(You run a cable from the spur to a junction box) , you then run a LNE to each of the fans (using plastic trunking or conduit if the cables cannot be sunk into a wall).
Inside the junction box you remove the Live supply cable from the connector which should now be carrying three cables leaving the two cables running to the fans.
Put the Live wire into the spare connector inside the junction box
Get a twin and earth cable with the two wires marked up as Lives (Brown or Red in the UK, or whatever your wiring colour code dictates in your country) take those to a single pole switch which is convenient to you and wire them in
Back at the junction box put one of those wire into the connector where the two Supply wires for the fans are and tighten them up
Put the second wire from the On/Off switch to the Spare connector in the junction box which is holding the Live Supply
You then have a fused supply with a switch to break the circuit
If you do not need a switch then ignore the second part and just rely on using the switched fused spur to control them.
You can use a single pole switch but it is safer to stick with the double pole version
The breaker will be out of the loop as that will provide the power and you should not be fitting wires to it
Jan 02, 2010 | Broan-NuTone Nutone Utility Exhaust Fan...
The fan and light switch are not working
I would begin by checking the electrical panel as the circuit breaker or fuse that sends power to the hood may have kicked or blown. If that is not the problem open up the wiring box in the hood. It is unlikely that bvoth switches would have gone bad at once.
Jun 14, 2009 | Broan-NuTone 433611 Kitchen Hood
No power
you have to take off the bottom part of the smoke hood and the lights and then you can look inside..the fuse is on the back of the push button panel...which is the control panel it is really small and hard to get out...you need some kind of wire that will hold its shape...to snake behing it aND PULL IT OUT...
Dec 16, 2008 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Changing fuse on Nutone Allure Ws2
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
Aug 16, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Everything stopped working?
Replace the transformer. Part #R501025 Its the smaller transformer of the 2. It has blue/yellow wires coming out of it.
I do service calls for broan-nutone.
Mar 20, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone WS330 Kitchen Hood Logo
57 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
