Question about Waterway Pool & Spa
When I installed a new waterway pump, model SD-10-1N11CB it is definitely sucking air, no leaks or obstuctions. When first started pump it actually collapsed the suction hose (like it was in a vacuum)
Waterway Model SD-10-1N11CB, Part No. PH11008D-6
    Top Expert:
  • Waterway Master
  • 5,062 Answers
Change suction hose or put hose clamps where it collapsted
Posted on May 01, 2016
3 Suggested Answers
  • 3600 Answers
SOURCE: Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Posted on Jul 05, 2009
  • 8404 Answers
SOURCE: Model #SD-20-2N11CC WATERWAY PUMP (2HP)
Rule of thumb for a 2 HP pump using a 2 inch pipe is between 60 and 80 gallons per minute. Factors affecting flow rate is the distance between the pump and the pool, how many bends and turns and of course the condition of the filter. If you need to meet a specific turn-over rate, use the lower number to determine in the event you sould be called on the carpet.
Low speed? I am sorry. I don't know the rule of thumb on this.
You could install a flow meter, available at your professional pool supply. They are easy to install and not a lot of money. Follow the installation instructions as best as you can.
Incidently, comercially speaking, the 'turn over rate' should be around 8 hours for a public pool. Your jurisdiction may have other standards. Commercial pools should run 24 hours a day at that rate during the open season. Turn over rate means all the gallons of the pool should go through the filter in 8 hours, or all the gallons should go through the filter three times per day. Example: 16000 gallons of water in the pool, your filter and pump should be pumping 2000 gallons per hour. Studies show that it actually takes up to 5 days to get every actual 'chunk' of water to go through the filter, so, many of the 'chunks' of water go through the filter multiple times per hour. BTW, I use the word "chunks" in an effort to better paint a mental picture of what is happening. I am not suggesting your water has "chunks" in it.
Thanks for your question @ FixYa.com
Posted on Jul 08, 2011
Waterway pump not priming
Foam will definitely keep a pump from priming. Why do you think it's the calcium causing the foam? I have added large amounts of calcium to pools and I do not recall ever having any foaming issues.
Check to see if your impeller may be clogged. Take the lid off of the pump and fill the basket up with water. Leaving the lid off, start the pump for three seconds and then turn it off. The water should be sucked away almost instantly. If the water level drops slowly you have debris clogging the impeller. If that is the case the pump needs to be opened and cleaned.
Jul 23, 2013 | Waterway Champion 1 1/2 Hp 230v Energy...
Failed operation
check pump strainer see if blocked with debris if ok clean filters and check top seal of pump
Jun 21, 2013 | Waterway 2hp Hi - Flo 2 Speed Above Ground...
I just installed a Waterway Above Ground Hi Flo 1.5HP pump on my above ground pool. Everything seems to be fine, but after turning it on, and it running for a minute or two, the pump starts to get louder...
sOUNDS LIKE ONE OF TWO THINGS.
1) The pump is cavitating (sucking in air) could be not enough water flow to it, or a leak.
2) The bearings could be bad or misaligned
Jan 18, 2010 | Waterway Above Ground Hi Flo Pump
REASSEMBLED WET END OF WATERWAY PF401A22C-LEAKS- NEED DIAGRAM
I've never seen a reassembly diagram for this particular pump but I'm guessing that you've installed the mechanical seal incorrectly.
Where is it leaking from exactly?
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Apr 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Pool & Spa Logo
62 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
