Question about HP Photosmart D7460 Printer
HP Photosmart C7280 Pump Motor Stalled?
I get a message 'Pump Motor Stalled' and when I try to print a test page I get an error code 0xc05d0082
3 Suggested Answers
fbibeau
  • 66 Answers
SOURCE: HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Posted on Mar 04, 2011
vinay229229
  • 1121 Answers
SOURCE: Error 0xc05d0082
Remove cartridges,switch off the printer, dis connect usb cable & power cable.. wait couple of minutes..powering it wait till message appears for consumables.. install consumables., install usb cable.. check...for message.. Remove CMOS battery mounted on formatter wait for couple of minutes, power it then check..
Posted on Jan 31, 2012
Error 0xc05d0082
Jan 31, 2012 | HP Photosmart C6100 All-In-One Printer
HP C7280 ink system failure error: 0xc18a0101
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
I hope this help those who have similar issues
Jun 16, 2011 | HP Photosmart C7280 Printer
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Jul 18, 2010 | HP Photosmart C7280 Printer
Ink pump error. code 0xc05d0082
First clear the NRAV system http://www.fixyourownprinter.com/forums/printer/50063
This did not help me but the solution was easy. I removed all the print cartriges (with the system powered up) then reinstalled them, let the printer go through its normal sequence then go to the Setup, select tools, them clean print head. This worked for me up and running again.
Good luck.
Oct 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart D7460 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
