Question about Mitsubishi WD-60638 DLP TV
Where can i find the lamp at - Mitsubishi WD-60638 DLP TV
Changing backup bulbs on 2005 buick rendevous
TAIL LAMP ASSEMBLY AND /OR BACKUP, SIDEMARKER, STOP, TURN SIGNAL BULB REPLACEMENT
REMOVAL PROCEDURE
1. Open the liftgate.
2. Remove the screws from the tail amp.
3. Slide the tail lamp rearward in order to disengage it from the retainers on the rear body panel.
4. Disconnect the electrical connector from the tail lamp wiring harness.
5. Remove the tail lamp and side marker lamp sockets from the tail lamp, depressing the locking tab and turning counterclockwise.
6. Remove the bulbs from the tail lamp and the side marker lamp sockets, if replacing the bulbs.
INSTALLATION PROCEDURE
1. Install the bulbs to the tail lamp and side marker lamp sockets, if removed.
2. Install the tail lamp and side marker lamp sockets to the tail lamp, turning clockwise until the locking tab is fully seated.
3. Connect the tail lamp electrical connector to the wiring harness.
4. Position the tail lamp retainer slots to the tabs on the rear body panel.
5. Install the tail lamp to the rear body panel, pressing into place until fully seated.
6. Install the tail lamp screws to the Taillamp.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp screws to 2 N.m (18 lb in).
7. Close the liftgate.
Apr 16, 2017 | Buick Cars & Trucks
I have a 2007 Buick Lucerne and the front reading lamps won't turn off.
Overhead Console Lamp and Roof Rail Courtesy/Reading Lamps
The courtesy/reading lamp is a duel purpose lamp that can be illuminated two different ways. First, the lamp can be turned ON during courtesy lamp operation as described above. Second, the lamps can be turned ON individually for reading lamp operation by the lamp switch. The BCM supplies battery voltage from the INT LAMPS fuse through the inadvertent power courtesy lamps circuit to the courtesy/reading lamps for reading lamp operation only. Ground for the courtesy lamp module or the roof/rail reading lamps is provided at G402
Courtesy Lamps
When either one of the front doors is opened, ground is applied through the door latch door open switch and the door open switch signal circuit to the door module indicting the door open position. In response to this signal, the door module sends a GMLAN serial data message to the BCM of the door open position. Or, when either one of the rear doors is opened, ground is applied through the door latch door open switch and the rear door open switch signal circuit to the BCM is indicating the rear door open position. Once a door open message or signal received, the BCM will then apply battery voltage from the CTSY/RF TRN fuse through the courtesy lamp supply voltage circuits illuminating the lamps listed below:
• Overhead console lamp
• Roof rail courtesy lamps
• Footwell courtesy lamps The BCM receives battery voltage from the INT LAMPS fuse in order to supply power to the inadvertent courtesy lamps. Inadvertent power courtesy lamp feature provides a similar function for the interior lamps as a retained accessory power feature. The BCM will energize the courtesy lamps supply voltage circuit when the BCM is in the active state (awake). When the inadvertent power courtesy lamps supply voltage circuit is energized, it supplies voltage to all the interior lights listed below. The BCM will continue to supply voltage to the interior lamps after the ignition is turned OFF so that the interior lamps may be operated.
• Overhead Console Reading Lamps
• Roof Rail Reading Lamps
• Vanity Mirror Lamps
• I/P Compartment Lamp
• Rear Compartment Courtesy Lamp
In the event that any of these lamps were to remain illuminated for a period of more than 20 minutes with the ignition switch in the OFF position and no BCM input activity, the BCM will deactivate the inadvertent power supply voltage circuit to prevent a total battery discharge condition. The BCM receives battery voltage from the CTSY/RF TRN fuse in order to supply power to the courtesy lamps. The BCM applies this voltage to the courtesy lamps through the courtesy lamp supply voltage circuits. When any door is opened, the door open switch contacts close and the BCM receives a door-open signal. If the BCM receives a door lock or unlock signal, the BCM will activate the courtesy lamp supply voltage circuit, providing battery voltage to the dome lamps and the left and right footwell courtesy lamps. The courtesy lamps can be manually activated by placing the interior lamp switch in the DOME position. For more detailed information concerning courtesy lamp operation refer to Interior Lighting Systems Description and Operation.
Jan 16, 2017 | Buick Cars & Trucks
Why aren't parking lights working?
Park lamp fuse 20amp located in the under hood fuse box .DRL control module
Daytime Running Lamps (DRL) Control Module
Right of the steering column, behind the IP
Park, Sidemarker, Tail and License Lamps
Voltage is applied continuously to the PARK fuse to the headlamp and the instrument panel (IP) lamp dimmer switch through CKT 1340.
When the headlamp and the (IP) lamp dimmer switch is in the PARK or HEAD position, voltage is applied to CKT 9 thus activating the following lamps:
• The park lamps
• The side marker lamps
• The tail lamps
• The license lamps
The park/turn lamps are the only lamps that do not activate yet receive a current from CKT 9. The park/turn lamps do not activate because the voltage drop across the front side marker lamps is much higher than that across the turn lamp filaments Step
Action
Normal Result(s)
Abnormal Result(s)*
Turn the headlamp/instrument panel (IP) lamp dimmer switch to the PARK position.
The following lamps light:
• The license plate lamps
• The taillight lamps
• The front side marker lamps (Domestic)
• The front parking lamps (Domestic)
The headlamp position lamps (Export)
Refer to Park Lamps Inoperative
Step
Action
Value(s)
Yes
No
Inspect the PARK LP fuse.
Is the fuse open?
YES - Go to Step 2
NO - Go to Step 3
Repair a short to ground in CKT 1340.
Is the repair complete?
Go to Exterior Lights System Check
Use a test light in order to backprobe the headlamp/IP lamp dimmer switch harness connector between terminal R and ground.
Did the test lamp light?
Go to Step 7
Go to Step 4
Use a test light in order to backprobe the headlamp/IP lamp dimmer switch harness connector between terminal O and ground.
Go to Step 5
Go to Step 6
5
Replace the headlamp/IP lamp dimmer switch. Refer to Headlamp Switch Replacement .
6
Repair the following conditions in CKT 1340 between the PARK LP fuse and the headlamp and the IP lamp dimmer switch harness connector terminal O:
• A faulty connection
• An open circuit
7
Repair the following conditions in CKT 9 between the headlamp and the IP lamp dimmer switch harness connector terminal R and S204:
• An open circuit
Feb 18, 2016 | 1999 Pontiac Montana
2002 ford expedition interior lights are not on what fuse is it?
Courtesy Lamps - central junction box. fuse # F1.21 that goes to interior lamp relay in the instrument cluster and F.24 this fuse powers battery saver relay .
Interior Lighting The interior light system consists of the following:
  • front map lamp assembly
  • front door courtesy lamp
  • generic electronic module (GEM)
  • glove box lamp assembly
  • central security module
  • interior lamp switch
  • interior lamp relay
  • illuminated vanity mirrors (Navigator only)
  • reading lamp assembly
  • rear courtesy lamp
  • running board lamp
  • underhood lamp assembly
  • The generic electronic module (GEM) illuminates the interior lamps when an unlock signal is received from the remote anti-theft personality central security module. The illuminated entry feature will be canceled when any of the following conditions are met:
    • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
    • The GEM receives a request from the central security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
    • The ignition is in the RUN or START position and the interior lamp control is not activated.
    The GEM will illuminate the interior lamps when any door is open or ajar. The interior lamps are; the dome lamp, the rear cargo lamp, the door courtesy lamp and the side rail lamps. The courtesy lamps will shut off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp switch is received.
    The GEM controls the interior lamps illuminated entry function by activating the interior lamp relay.
  • You have an electronic control module and relays involved in the operation of these lights also !
  • What
    Jan 08, 2015 | 2002 Ford Expedition
    Red lamp light is blinking. Replaced lamp and light is still blinking.
    The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
    Description of product:
    Replacement RPTV projector lamp HITACHI 50C10
    Supplied equipment: gloves, filter
    Lamplife (hours): 5000
    Performance (W): 100
    Lamp type: UHP
    Changing the lamp:
    1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
    2. Find the lamp cover on the projector and remove it by loosening the screws on it.
    3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
    4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
    5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
    6. Install the new lamp according to the aforementioned instructions in the reverse order.
    7. Turn on the projector and turn the lamp operation counter to zero.
    Changing a bare lamp without module:
    4. Grasp the lamp by its wire handrail and carefully remove it.
    6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
    7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
    8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
    9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
    10. Insert the new lamp into the module and tighten the connectors.
    11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
    12. Turn on the projector and turn the lamp operation counter to zero.
    Reset the lamp counter hours of operation for the projector HITACHI 50C10
    1. Turn on the projector
    2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
    3. Select the "RESET" function
    4. The counter is at zero
    Product websites:
    www.hitachi.com
    Dec 03, 2010 | Hitachi 50C10 LCD TV
    How do you replace the tail light bulbs on a 2006 Pontiac Vibe
    Tail Lamp: Service and Repair
    TAIL LAMP REPLACEMENT
    REMOVAL PROCEDURE
    1. Open the rear compartment lid.
    2. Remove the rear compartment trim panel (4).
    3. Disconnect the tail lamp electrical connectors.
    4. Remove the following components from the vehicle:
    - The 3 nuts (3)
    - The tail lamp (7)
    5. Remove the following from the tail lamp:
    - The stop lamp socket (2)
    - The turn signal lamp socket (5)
    6. Remove the following from the lamp sockets, if necessary:
    - The stop lamp bulb (1)
    - The turn signal lamp bulb (6)
    1. Install the following to the lamp sockets, if removed:
    2. Install the following to the tail lamp:
    3. Install the tail lamp (7) to the vehicle. Secure the tail lamp (7) with the 3 nuts (3).
    Tighten the tail lamp nuts to 10 N.m (89 lb in).
    4. Connect the tail lamp electrical connectors.
    5. Install the rear compartment trim panel (4) to the vehicle.
    6. Close the rear compartment lid.
    Oct 30, 2009 | 2003 Pontiac Vibe
    I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
    Hello there:
    here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
    best regards michael
    1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
    2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
    3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
    4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
    5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
    6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
    lamp
    Sep 24, 2009 | Electrical Supplies
    Lamp doesn't light on SP 500, SP-Lamp-017. How do
    you'd need the lamp on to get into the menu to reset the timer, so it's not that. if the door hits and activates the switch, it may be the ballast.
    Aug 09, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
    NEED TO REPLACE A TAIL LIGHT BULB IN A 2005 CHEVROLET IMPALA
    and Repair Notes TAIL LAMP REPLACEMENT REMOVAL PROCEDURE Open the rear compartment. Remove wingnut and pull back the rear compartment trim panel from the tail lamp. Remove the wingnuts from the tail lamp. Remove the tail lamp from the rear body panel. Disconnect the electrical connector from the tail lamp. Remove the tail lamp socket, turning counterclockwise. Remove the bulb from the tail lamp socket. Remove the sidemarker lamp socket, turning counterclockwise. Remove the bulb from the sidemarker lamp socket. INSTALLATION PROCEDURE Install the bulb to the tail lamp socket. Install the bulb to the sidemarker lamp socket. Install the sidemarker lamp socket, turning clockwise. Install the tail lamp socket, turning clockwise. Connect the electrical connector to the tail lamp. Install the tail lamp to the rear body panel. Install the wingnuts to the tail lamp. Pull back the rear compartment trim panel to the tail lamp and install the wingnut. Close the rear compartment.
    Jun 08, 2009 | 2005 Chevrolet Impala
    Christie DS+60 projector turns off spontaneously
    Here is a list of error codes for your unit:
    12 Software bug. Contact dealer/factory.
    13 Flash memory corrupted. Download new software.
    14 Engineering only programming is complete. Call Christie, replace TIPM.
    15 Attempting to download code without being in boot mode
    16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
    17 Forced boot mode. Keys held down too long.
    18 Attempting to program boot mode without jumper
    LAMP FAILURES
    21 Lamp compartment too hot
    25 Lamp 1 not installed
    26 Lamp 1 Interlock: door open, lamp not installed
    27 Unable to turn lamp 1 ON
    28 Lamp 1 shut off unexpectedly
    29 Lamp 1 driver overheated
    2A Lamp 1 driver operation error (e.g. too hot can’t start)
    2C Lamp 1 driver UART communications failure
    30 Lamp 2 not installed
    31 Lamp 2 door open
    32 Unable to turn lamp 2 ON (unknown reason)
    33 Lamp 2 shut off unexpectedly
    34 Lamp 2 driver overheated
    35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
    36 Lamp 2 driver UART communications failure
    37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
    Jan 16, 2009 | Christie DS+60 Multimedia Projector
    Mitsubishi WD-60638 DLP TV Logo
    19 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
