Question about Sony KDL Televison & Video
Phantom image, display color green, blue and red only
4 Suggested Answers
Edcyl1856
  • 16 Answers
SOURCE: green color screen
check all posible leak and reheat UOC chips, replace EEPROM
Posted on Nov 17, 2007
mistersony
  • 320 Answers
SOURCE: Color Hue tends toward green
Sounds like a bad optical block
Posted on Oct 18, 2008
jomabug76
  • 1148 Answers
SOURCE: Image green tinted.
TRY VIDEO CONVERSION OPTION IN THE MENU,,IF NOT TRY NEW CONNECTERS
Posted on May 15, 2009
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
18c808 aa subwoofer with amp from Focus. How do I install it?
ask here
http://www.f150forum.com/f75/how-fix-your-subwoofer-amplifier-7l2t-18c808-aa-227544/
or
Diagram 7l2t 18c808 aa - Dual Ford Mustang Convertible 94-12 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
Oct 23, 2015 | Ford Cars & Trucks
All the colors for all programs are blue and yellow on tv. have tried all the picture settings but nothing changes.
hi" do you try to adjust color settings.theres a red,blue,green color adjustment under picture setting.
try to set red color to full.
of you already do that.
probably your display driver board has a causes the problem.
display driver board produce image comes from the tuner, then it sent to x and y drive of your LCD screen.
Aug 30, 2011 | Sanyo DP26647 26 in. LCD TV
The yellow blue and green.. which one is video plug?
What you have is a component cable. By the sound of the cable it seems like you might have this kind:
http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
The Yellow / Blue / Green / Red cables are all meant for video. The back/side of your display will either have matching colors, or it will just have a yellow, white, red. You want to plug in the Blue, Green, and Red cables. If your display doesn't have this, it's not capable of component video, in which case you will want to plug in the Yellow / White / Red into the AV slots.
Dec 26, 2010 | Dynex DX-LCD32-09 LCD TV
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Picture is red
If you are running component video, make sure the blue is plugged in and in the right spot. Component video works like this: the green is a black and white image, the red and blue are cover overlays to make the image display properly. So if everything looks plugged in right, then try plugging in a composite video (Yellow) or S-video cable switching to the appropriate input, and see if the image is still red. If so, go to the set up and set the set to factory defaults, and see if that fixes the color issue, It's possible that the color settings on the TV are messed up, with the S-video plugged in go through the set up menu and see if you can correct the color issue IF THE IMAGE IS STILL RED WITH THE S-VIDEO OR COMPOSITE VIDEO, otherwise the issue is a problem with the component video cable.
Oct 01, 2009 | Philips 60P8342 60" Rear Projection...
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Televison & Video Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
