Question about HP 12c Calculator
Sharp EL-531XH set the decimal - HP 12c Calculator
EL-531XH. Why don't 0-1-4-7-9 buttons work?
Dropping calculators or mistreating them is known to make them behave strangely.
Aug 25, 2015 | Sharp Office Equipment & Supplies
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Increase the decimal places
Press SETUP, select FSE, select FIX, then enter the number of digits you want to the right of the decimal point.
May 10, 2014 | Sharp EL Office Equipment & Supplies
Set sharp el-738 to six decimals
A takeaway restaurant receives on averege 20 orders per day for its delicious meals. determine the probability to four decimal places that the takeaway will receive exactly 15 orders per day.
Jan 24, 2014 | Sharp EL-738 Scientific Calculator
How do you reset sharp EL-531XH calculator
There's a small hole in the back marked "RESET." Poke a straightened paper clip or similar implement into the hole.
Aug 04, 2013 | Sharp El-531x Scientific Calculator Green...
How do you reset a sharp EL-531XH
There's a small hole in the back labeled "RESET." Poke a straightened paper clip or similar implement into the hole.
Aug 04, 2013 | Sharp Office Equipment & Supplies
Hi I have a sharp el-W535 and want to know how to get rid of the fracton in the line editor as the answer so I can get .500 for example
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 26, 2011 | Sharp ELW535 Calculator
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Nov 11, 2008 | Sharp EL-531VB Calculator
HP 12c Calculator Logo
35 people viewed this question
Seeker5211
Seeker5211
