Question about Kenmore 24032\24036 Top Load Washer
My Kenmore 80 series topload machine is leaking water
My Kenmore 80 series topload washing machine is less than 4 years old and it is only my husband and I in our home - no children - so it is not used a lot and it is now leaking water from the bottom of the machine. A piece of junk, along with the Kenmore dryer which does not dry well either. DON'T SHOP SEARS CANADA
    President:
  • 744 Answers
This machine has a direct drive pump, in all likelyhood the pump is leaking...unplug machine...pull it out...tip machine on its back so you can access the bottom, if it is the pump there should be water around where the pump connects to the motor, if it is the pump it is a simple process of releasing 2 clips and taking the inlet and outlet pipes off the pump..install new pump the way you took old one off. you can obtain the part from www.repairclinic.com If you would like to give me more details on your dryer i may be able to work out what is wrong with it.
Posted on Jun 23, 2009
I have a Kenmore 80 series about 4 years old and it is leaking. Had a repair man over 3 months ago and it did not leak. However, I see my baseboard behind the washer pulling away and ran a small load...
check to make sure the drain hose is all the way in the drain pipe in your wall. there should be a strap, or tie wrap holding it in place to keep the water pressure from pushing the pipe out of the drain during the drain cycle. if not, the water pressure will cause the drain hose to rise up and allow water to leak down the wall. use a flashlight. you should be able to see a trail of water residue leaking down the wall. slide the washer out a bit and run it. see if the water is coming from the wall, or leaking out of the washer itself. let me know and we can go from there.
Nov 20, 2010 | Kenmore 24902 Top Load Washer
Mildew smell in washer
there is a chemical you can get to help with the smell from SMELLYWASHER.com
Feb 19, 2010 | Kenmore 22942 Top Load Washer
Efficiency of Kenmore 80 and 90 series washers
all front loaders do is save alittle water,motor and pumps aree almost the same,kenmore makes the 300,400,500,600,series know and they will last forever,and if you do need a replacement part they are dirt cheap,because all parts are universal-mike
Feb 05, 2010 | Kenmore 15944 Top Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing machine
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub. culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Jun 10, 2007 | Kenmore 20172 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
445 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
