Question about Sharp EL Office Equipment & Supplies
Increase the decimal places
El-531xh who to set up the calculator into decimal
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Press SETUP, select FSE, select FIX, then enter the number of digits you want to the right of the decimal point.
Posted on Nov 20, 2014
SOURCE: decimals
This is an easy one and happens often. Simply depress the orange "f" key and then select how many decimal points you want on the numeric keys. For example, for two decimal places you would push "f" 2. I usually keep mine on 3, but you can take it from here.
Posted on Apr 25, 2008
SOURCE: sharp el506d calculator has the decimal in the wrong place.
Try pressing the FSE button to switch between Fixed, Scientific, Engineering, and Normal displays. When in Fixed display, you can use <2ndF> < TAB > then enter a number from 0 to 9 to choose the number of decimal places in that display. To reset EVERYTHING to factory defaults: With the calculator off, press and hold these three keys: <2ndF> < ) > < ON/C > then release all three. The calculator will go through a series of tests (it takes a few seconds) and then be at its factory defaults. I have uploaded the manual for this calculator at www.theusermanualsite.com.
Posted on Dec 09, 2008
SOURCE: I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
How to increase the decimal places in the answer
Press 2ndF TAB then a digit representing the number of digits after the decimal point. See "Adjusting the Displayed Decimal Places" beginning on page 7 of this manual: http://www.fixya.com/support/p193841-sharp_el_733a_calculator/manual-5340.
That's the page numbered "7" in the manual, not the seventh page of the PDF file.
Oct 31, 2013 | Sharp EL-733A Calculator
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
I need to increase the decimal places displayed on my sharp el 738 calculator. Please help......
From the manual PDF http://www.yorku.ca/ntahani/ADMS3530/EL738_OM.pdf
(page 8 and 9)
decimal places:
set up - 0 - 0 - (tab) displays DIG(0-9) select a number from 0 to 9 decimal places
significant digit:
setup - 0 - 0 - (SCI) displays SIG(0-9) again select a number from 0 to 9 to set...0 sets a 10 digit display
the floating point FLO_A and FLO_B is a nice little chart so i'd advise downloading the PDF if you need to set those :)
Sep 21, 2011 | Computers & Internet
I want to set the decimal place without using the decimal key--example: hit the 1234 keys and the shows $12.34
You can select the A (K . A) and then the # of decimal places (F 6 3 2 1 0) you want. So if you want to enter 1234 & it calculates 12.34, this will work.
Jul 22, 2011 | Sharp EL-2630P Calculator
How to add decimal on SHARP EL735S
how do i increase decimal places on a sharp el735?
Jun 02, 2010 | Sharp EL-738 Scientific Calculator
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Nov 11, 2008 | Sharp EL-531VB Calculator
108 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
