Help
This may be a faulty inlet valve. If you are good with electrics and have a multi meter remove terminals from inlet valve, insert the leads into the terminals...run the dishwasher...if the valve is bad you will get 120v within the first minute or so of starting the cycle...basically the machine is calling for water but the valve is not opening...if the valve is bad...remove it and check the strainer screen for a blockage before buying a new valve.
Hello friend, thank you for your post!
Your water valve or spray arm could be the reason no water is getting to the top of your dishwasher. Remove the spray arm and clean it out with warm water. Also check to make sure that nothing is obstructing the spray arm from releasing water onto the dishes. I hope this information is helpful. -Matt
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
