Question about Simplicity Regent 19.5/38
Why does my simplicity regent 24 hp not turn over?
It will usually start after turning the key 4 to5 times then it turns over. When it doesn't turn over there is a whine coming from the motor area, cant pinpoint it
  • 24 Answers
For some reason your starter gear isn't coming up to meet the flywheel to turn it. That's why you hear the whineing. If you can take the starter off and take it to your local repair shop and they can fix it for you.
Posted on Feb 28, 2015
Simplicity regency 12 hydro sucking oil into carburetor. what could be the problem?
blown head gasket... it pressurizes the engine causing oil to blow out...
or
oil is WAY to full
should of mentioned the engine brand because simplicity doesn't make it !!!
Oct 18, 2014 | Simplicity 2691011 - Regent 42" 21HP Lawn...
How do I tighten my drive belt on my simplicity lawn tractor because it keeps slipping off when I make left turns?
Check air pressure in your tires, and if you look around your deck pulleys you may find 1/4" adjustment bars that you can loosen and move in towards your pulleys. These bars, if you have them there, keep the belt from falling off. But my first suggestion should help you. GOOD LUCK FRIEND.
Sep 21, 2014 | Simplicity 38in Regent 21hp Briggs
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
12 hp briggs backfires doesn't start
This could be a result of several different things, however the most common of these would be a sheered flywheel key. If this is the case it has throwed the motor out of time and is trying to fire while the exhaust valve is open causing the backfire and lack of compression to start. I hope this has helped.
Sep 30, 2013 | Simplicity "Citation 61"" 28-HP Briggs And...
1999 simplicity landlord tractor doesn't start
Does it crank? There are a myriad of issues to check
Dead battery
Bad battery connections
Safety switches not all in right setting (like a PTO/mower deck turned on that needs to be off for starting, or a brake pedal not pressed, or a seat not sat on)
Bad solenoid
Bad fuse
Bad relay
Bad starter switch
More details can narrow it greatly. Have you tried jumping it? Do you get noise when you turn the key? Was it an all of a sudden problem, a growing intermittent one, have you tested the voltage of the battery or tried charging it? Etc.
Mar 30, 2013 | Garden
How to drain gas from snapper zerro turn mower
Take the fuel line loose at the petcock or filter. Should have a snap ring there.
Jan 08, 2013 | Simplicity Snapper Pro 36" Zero Turn Lawn...
Simplicity Regent Starting Problem
The wrong seat switch was installed. There are black ones and gray ones. I believe you need the gray one for open circuits.
Aug 10, 2012 | Simplicity Regent 19.5/38
1999 chevy suberban. it will turn over but wont start, I turn the key to start position no dash lights come on for about 3 to5 seconds the fuel gauge pegs to full then goes to normal position, at that time...
There is a good chance that your ignition keys need to be replaced, you can pick up a replacement ignition lock switch at Auto Zone and they will have the step by step instructions to getting the job done.
Thank you for using fixya and good luck
May 08, 2010 | Chevrolet Suburban 2500 Cars & Trucks
Simplicity Regent 19.5/38 Logo
104 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
Will Mishler
Will Mishler
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
