Question about Adventure Power UT5L Scooter Battery for MANCO 5051 L 50CC 06
Starter not engaging on matrex scooter
Put new battery inand starter will not work
ANY IDEAS WHY OUR CPI GTR 50 SCOOTER HAS NO POWER?
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter control circuit, relay, or solenoid faulty.
11. Main fuse or circuit breaker may be blown or faulty.
12. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
CPI GTR 50 HELP
Chinese Scooter Club View topic No DC Voltage to the CDI
Scooter Troubleshooting Scooter won start All about Scooters
http://www.49ccscoot.com/manuals/CPI_GTR50_Service_Manual.pdf
Aug 02, 2016 | 2005 Cpi GTR 50
How do I fix Jordan scooter that wont start
Hi, Anje and the usual suspects are:
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.Scooter Troubleshooting Scooter won start All about Scooters Scooter won start
http://www.sym-center.ru/files/jet-all.pdf
Jan 15, 2016 | Jordan Motorcycles
Pride Celebrity x. Batteries drain quickly despite new full charged batteries. When scooter is pushed in freewheel- brakes engage every few feet. Have to turn scooter on/off to get brakes to release.
hi Diane, the brake engaging is by design, distance is the key here
Have you tried another charger ?
1. when pushing the scooter in freewheel before the brake engages , is it easy to push ? what can happen is the brake does not release 100%, a easy test is to run the scooter then put your hand on the brake unit , is it hot ? be careful because it could be very hot , this will prove the brake is not releasing fully.
Regards
Rob
Dec 09, 2015 | Pride Health & Beauty
What is the main cause of un passing electric to start
Hi, Bijualexander and the usual suspects are:
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
50CC Scooter Wont start
How To Fix Scooter Starting Issues Part 1 Quick Guide
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
50cc scooter wont start need help
Scooter won start
Apr 26, 2014 | Bajaj Motorcycles
Scooter beeps and won't go. Gear doesn't click into "engaged" mode sometimes. It seems to slip between "engaged" and "freewheel".
sounds to me like the starter solenoid that's what I would replce first , then look towards new battery's if that fails .
Mar 28, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Put in new batteries and scooter does not move fwd or rev
If you are not getting an operating light, the batteries are probably not installed properly. If you are getting a ligh check that freewheel mode isn't engaged. The manual for this scooter is at
http://www.goldentech.com/wp-content/uploads/FullSizeLuxury/CompanionOwnersManual%20081409.pdf
Page 23 Shows battery removal for disassembly, and page 28 is your battery instructions.
Oct 07, 2013 | Golden Technologies Companion II Travel...
Diamo scooter kick starts electric starter not wiring
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
http://www.linnbenton.edu/auto/perform/no_start.html
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial http://scmotorized.com/image/data/pdf/scooter-repair-manuals/Retro-150--Parts-Catalog-V.12.07.pdf
Diamo Retro 150 2007
Sep 24, 2013 | 2007 Diamo Retro 150
Starter turns slow
poor connection or ground cables can look good and be bad just like me! also the sarter could be the problem if the relay isnt carrying enough amps when the starter engages
Dec 08, 2007 | Harley Davidson Harley-Davidson Motorcycle...
Adventure Power UT5L Scooter Battery for MANCO 5051 L 50CC 06 Logo
Top Adventure Power Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Adventure Power Health and Beauty Expert? Answer questions, earn points and help others
