Question about Beko Refrigerators
Machine trips main fuse - Beko Refrigerators
5 Suggested Answers
wagdom
  • 64 Answers
SOURCE: Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
Posted on Oct 21, 2007
  • 86 Answers
SOURCE: MAINS ELECTRICITY FUSE TRIPS WHEN DISHWASHER TURNED ON
Hi, I think you will need to check the heater or the wash pump, as these are the first things to energised. IOf yo could give me some more information then i could tell you where to after these things have been tested ok!
Get back to me......
Posted on Jan 10, 2009
kachbibi1
  • 979 Answers
SOURCE: LG 1412RD Tips main fuse.
You have a dead short either in your breaker box or the plug in. Chances are it is your receptacle.
Posted on Feb 24, 2009
beltronic205
  • 1474 Answers
SOURCE: washing machine starts but trips mains MCB,
Sounds like short or Electrical leakage,,locate and disconnect the heating element then try this goes faulty now and then....Machine should then run /spin fill ...if so fit new heater
Posted on Feb 10, 2011
TRIPS FUSE IN MAIN HOUSE BOX
you may have to add a different fuse line in your box....PLEASE DONT ADD IT TO EXISTING FUSE LINE
Sep 23, 2014 | Zanussi Washing Machines
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
Washing machine tripped main fuse breaker, now won't work
Yes. It may be an internal safety fuse or switch. RJ
Sep 29, 2017 | Candy Washing Machines
Washing machine
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
Apr 05, 2008 | Indesit W 123 Front Load Washer
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Refrigerators Logo
12 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
