Question about Canon PowerShot D10 Digital Camera
Canon D10 Shutter button not working?
Unable to capture photos as shutter button is not working. Otherwise camera is fine. Even when i click the photo isn't captured. Can it be a problem with settings?
  • 10 Answers
SOURCE: Canon powershot A85 photo capture problem
Sencor is bad,I have repair this before.
Posted on Sep 14, 2007
t00nz
  • 4738 Answers
SOURCE: Screen all fuzzy when taking photo.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
SOURCE: Canon 40D not firing
Try doing a reset in the camera tools somewhere, this fixed a similar problem I had.
Posted on Feb 06, 2009
  • 164 Answers
SOURCE: Canon S515 - Cannot depress shutter
Reset your camera to the factory settings. it will fix it.
Then, you can start changing the settings again.
Best regards,
Posted on Jul 25, 2009
SOURCE: with a canon 1000d, shutter button wont work, have
try to disable the mirror lockup at C.fn no. 8
Posted on Dec 12, 2010
I have Canon PowerShot A460 .When i capture a picture it look utterly bright both on Camera Screen and in PC. It flashes both in night mode and in day light or sun light. I 've reset all the functions...
I suspect that your shutter has stopped working. When you take the photos in good light, the shutter stays open causing total over exposure. I bet if you take a photo at night in a dimly lit place with flash, the photos would be fine as this does situation does not rely on the shutter.
Jul 24, 2011 | Canon PowerShot A460 Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
Shutter button flew off on Christmas day. Luckily was indoors. Found the spring and button, cellotaped together and worked fine until yesterday whilst taking photos, the shutter button suddenly stopped...
shutter mechanism inside may not be in contact with the actual shutter button...or shutter mechanism might have failed altogether.this one's definitely recommended for repair.
Apr 16, 2010 | Sony Cyber-shot DSC-H5 Digital Camera
Canon 1D shutter problem
may be shutter not opening fully some grit dust in it i had thia prob with my camera cleaned it and it was fine
Sep 15, 2009 | Canon EOS-1D Mark II Digital Camera
Used to take great photos. Now lots are blurred.
Camera or hand shake are the most common cause of blurry photos, long exposure needs slower shutter speed, this is happened when your subject have inadequate light, and during this process, the camera sensor/shutter is open, causing the resulting photo to be blurry, because even a single movements of your camera or hand will cause the camera sensor to move, that causes a blurry capture. In order not to experience this, you have to be familiar with the setting of your camera, there are 3 important settings you have to understand: ISO Setting, Shutter Speed, and the Aperture Setting, they are related with each other. ISO Setting, is the sensitivity of your camera to light, meaning the higher the ISO, the more sensitive your camera in light, and the more sensitive, the faster your shutter speed. ISO scale from 100, 200, 400, and so on, depends on the cameras specs. Shutter speed, is the speed of the opening and closing of the camera's curtain( e.g. 1/30, 1/60 of a sec....and so on) and Aperture is the opening size of your lens focal points (the lower the f, the wider the opening: f1.4, f1.8, f2.0, f2.8, f3.5, f5.6, f8, f11, f16, f22, f32
I hope this will be helpful.
Jul 19, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Shutter problems
I am having a similar problem with my eos 100QD.
shutter opens, then stays open until I depress the shutter switch again.
Sometimes about half my photos are lost on a roll, but the other photos are fine (as would be expected from how the film is wound). This problem looks like it's caused by the shutter mechanism failing, a common problem with older camera and one that is often more expensive to repair than it is to replace the body.
May 25, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
PowerShot A85 capture fault
Yup, it is a common problem. The shutter is jammed. I bet outside pictures are really overexposed. The horizontal lines are caused by the electronic noise created by the shutter solenoid trying to move the shutter. If the cameraq is no longer under warranty- Sometimes, you can free up the shutter by banging the camera in a hard surface like a desk or table. (Do this carefully, don't get carried away) If this doesn't work, you will need to replace the whole lens unit. this is best if the warranty is still good.
Apr 04, 2007 | Canon PowerShot A85 Digital Camera
Canon PowerShot D10 Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
