SOURCE: HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
SOURCE: Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
SOURCE: HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
