Question about Cell Phones
Zass error cod - Cell Phones
ERROR COD C6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
May 04, 2014 | Kyocera FS-1118 Printer
Mi copiadora IR 5020 se para y arroja cod E 0000020 y manda a apagar y encender el equipo que es este error
check the toner hopper maybe the toner is empty or the hopper motor is failed to fuction
Dec 03, 2010 | Canon imageRUNNER 5020 Copier
Fax -L380 canon error cod Eooo
Fixing assy failure. Replace fixing assy.
May 18, 2010 | Canon FAX-L380 Plain Paper Laser
Error 907 invalid cod file.. Message pops up when i try to download tether to blackberry
Try to access the .jad directly by browsing to http://tether.com/t/tether.jad
I've found third-party sites hosting applications causing this error to occur on my 7100i
May 13, 2010 | RIM Sprint/Nextel 7100i Smartphone
Jx6,x300 erro Cod P1621p1621
That code is for Engine control module engine immobilization input circuit malfunction. Ignition coil is ok.
Apr 09, 2010 | 1995 Jaguar XJ6
Everytime I load COD 6 it keeps saying ''disk unreadable''
cod has sum kind of disk error how long you had your system
Nov 12, 2009 | Microsoft Xbox 360 Console
I loaded the update for my blackberry and got an error jvm error 102 and now the phone will not charge or turn on i have tried a new battery and that does not work. It does not show like its charging or...
Sir, The system checked the COD files in the device for modification and determined that a problem exists with one or more COD files.If all loads fail, a build process error might occur (a problem exists with signing the COD files).If a user action on the device resulted in this problem, the reset cycle is continuous because the code in the filesystem has been corrupted. The only recovery method is to wipe the device and restore a new system.
Jul 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Script compile error
Is this COD??
If so back up your gamesaves from COD to a meme stick.
Then put COD in and see what happens.
If it works then the game save was corrupt.
And yes you will have to start again.
Feb 25, 2008 | Microsoft Xbox 360 Console
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
