Question about Sears Scrollsaw Woodworking & Crafts
Why do i have excessive vibration /broken blades with a sears scroll saw
    Genius:
  • 1,406 Answers
You have poor quality blades (try Olsen blades), or
You're forcing the work past the blade (just "offer" the work to the blade, let it cut, don't force it to cut), or
Your tension is too high, or
Your tension is too low, or
Your blades are getting installed upside-down (teeth point DOWN).
Posted on Jul 29, 2014
How do i replace the blade on my Sears craftsman 16 in. Direct drive scroll saw model no. 113.235501 , please help
the blades will have small pins at each end
fit it in the table end first as this is the end that does the work
then pull the top down to fit the blade in the slot
The top is normally only spring loaded
Aug 08, 2015 | Craftsman Saws
I have a Sears 22 inch lawn mower, model #917.376070, Serial number 121906M-029886. I recently purchased and installed a new blade from the Sears parts store in Milwaukee (part no. 917-141114) and...
The blade only cuts on the outer 4 inches of the blade rotation(diameter). As the mower moves forward, it cuts the full width of the deck. If sprigs of grass are missed or excessive vibration is present, you may have a bent crankshaft. Check and be careful, ejection of the blade hazard exist.
Jul 17, 2017 | Computers & Internet
How do you answer my question? Do you email an answer or what?
maybe the watcher is not placed properly and the blade wiggle
Dec 20, 2012 | Bosch 12" Compound Miter Saw 3912
I have an old Sears Jig Saw, model 110 25710, that has a broken blade. I need a new blad and instructions on how to remove the broken one, and replace it with the new one. Can you offer any assistance?
Take a look at the point of blade locking to the tool. Should be 2 hexagon bolts. Using the right size tool, unscrew them carefylly, pull out the broken blade, go to your local hardware store, and get a new one that will have the same size on the tail. ( the side that gets inside the slide on the saw). Slide the new blade to the saw, and tighten the bolts back but do it equally twisting them in turns, half a turn each time to keep the blade staying straight.
Whole thing should last no more than 5 min. ( Remember to keep the power cable unplugged all the time you make the change. Your fingers are priceless).
Sep 08, 2010 | Sears Saws
I can't get the bolt off to replace the blade
Sometimes these blade bolts are torqued excessively by the maker so they won't come off easily. Made sure you lock the blade somehow, and use a breaker bar long enough to get good leverage. Or maybe the bolt is lefthand thread?
Apr 29, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Scroll saw Model 572.247200 need manual or at least what saw blade it takes??????
According to the Sears web site, your sroll saw uses the #8030 blades, which have been replaced with #5088029. These are available from any Sears store or online at the following link, see item #31 or 31A, priced at $4.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=+572.247200+&productCategoryId=0744440&brandId=0247&modelName=CRAFTSMAN-15-INCH-MOTORIZED-SCROLL-SAW%2FSANDER&diagramPageId=00001&documentId=00033222&pop=flush
It would appear that the owners manual for your scroll saw has been discontinued and is no longer available (Sears #405015) But the line drawing and parts list may be of some value to you, should you need to do any repairs later on.
I hope you find this Very Helpful and best regards!
Oct 23, 2009 | Saws
I need to replace the blades on a Sears Scroll saw. Model # 149236160
Your scroll saw should have come with Hex end tools to use when changing out the blade. You must release the tension on the blade (located on top of arm above blade). There is a small allen head screw which has to be loosened with an allen wrench to release the blade. There is also an allen head screw under the working surface which will have to be loosened to remove blade at the bottom. Replace blade at the bottom 1st, tighten up then go to the top, tighten it, then reset the tension and you're ready to saw again. Make sure to get a visual on the directions of the blade teeth before you remove it so you can replace the new one the same way. I hope this is helpful.
Sep 26, 2009 | Craftsman Saws
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Saw blade broke. motor won't run after changing blade. reset wasn't tripped. lite still works so its not in the power cord.help! this is a craftsman 16 in. variable speed scroll saw not used very much....
It would have cost more to have Sears fix the saw than I paid for it, so I got my meter out and by checking the voltage drops across all of the electrical connections in the saw , I determined that the on / off switch was defective. This switch is the same switch used to turn the lite on and off, so I took the switch out of the lite and used it in the saw. I ordered a new switch for the lite and will install it when the new one comes. Thanks for your interest and help. fletcher1
Jul 17, 2009 | Craftsman 16" Variable Speed Scroll Saw
Sears Scrollsaw Woodworking & Crafts Logo
111 people viewed this question
Top Sears Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Sears Craft and Hobby Expert? Answer questions, earn points and help others
