Question about Swisher Zt2560 Zero Turn Radius 60" Riding Mower
How to change oil - Swisher Zt2560 Zero Turn Radius 60" Riding Mower
How to reset change oil soon light
Oil Life Monitor Resetting (KD, KE)
Description
The engine oil life monitor will indicate when to change the engine oil and the engine oil filter - usually between 5 000 km (3,000 miles) and 12 500 km (7,500 miles) since the last oil change. Under severe conditions, the CHANGE OIL message may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 12 500 km (7,500 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5 000 km (3,000 miles) or sooner if the CHANGE ENGINE OIL message is displayed.
Reset the oil life monitor when the oil has been changed.
Resetting Procedure
Press the INFORMATION SKIP button on the DIC control panel in order to display the OIL LIFE LEFT message.
Press and hold the RESET NO button until the display shows 100% ENGINE OIL LIFE.
Jan 29, 2016 | 1999 Cadillac DeVille
Reset oil change milage
GM OIL LIFE SYSTEM - RESETTING
The engine oil life monitor will indicate when to change the engine oil - usually between 5 000 km (3,000 miles) and 16 000 km (10,000 miles) since the last oil change. Under severe conditions, the "CHANGE OIL SOON" light may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 16 000 km (10,000 miles) or 12 months without an oil change.
Reset the oil life monitor when the oil has been changed, use the following procedure:
  1. Turn the ignition key to the RUN position.
  2. Fully push and release the accelerator pedal 3 times within 5 seconds.
  3. If the Change Oil Soon light flashes, the system is resetting.
  4. Start the vehicle.
  5. The oil life will change to 100%.
  6. If the Change Oil Soon light comes back on, the system has not reset. Repeat the procedure.
Mar 06, 2011 | 2004 GMC Sierra 1500 Crew Cab
At 28,066 dealer oil change. At 28,778 dealer flushed engine to remove sludge build up and changed oil. At 30,835 miles inspection, dealer flushed engine to clean out sludge and changed oil. At 34,630...
First dealer was NOT doing you any justice. Next oil change run a can of GUNK engine flush let idle 5-10 mins then change Oil & Filter and use a good oil like Castrol or Valvoline 10w-30. You won't have "supposed" sludge build up.
Mar 02, 2011 | 2000 Chrysler Town & Country
I have a 2002 hyundai santa fe. I want to change the oil filter on it but not the oil itself. I was told that to change the oil filter on this car you have to have a complete oil change. Is this true? I...
neither have i to be honest ,i change oil filter every third oil change on my regular customers cars with a oil change every 6000km or so ,never a problem and i have often changed a filter on some cars without changing teh oil where the metal cannister has started leaking
Jan 19, 2011 | 2002 Hyundai Santa Fe
When I check the oil it smells of gas motor run strong but why would there be gas in the oil?
your oil may be breaking down,try a really good oil change with a fram oil filter,recommend that you use castrol 30 weight oil in winter and 40 weight in summer,also add lucas oil treatment in with the oil change,it gives great top of motor lubrication,not like regular oil.fram filters are great too,they won't fold under pressure like a cheap one would.when you refine oil,it turns into gas.if you've been using a quick oil change place,stop. find a mechanic that can change your oil. you go to parts store,purchase an oil change kit with 30 weight castrol oil,tell them you want to add lucas oil treatment in on the oil change and have them look up your engine to see how many quarts of oil it takes,make sure they know that you want to add the lucas in on the oil change so you don't overfill the oil.after you've purchased the oil change kit,then go to your mechanic with your supplies and have them change your oil.after you've done this once,you'll do it all the time.quick oil change places buy their oil in bulk and as cheap as possible,then charge you for quality products.they break down quicklyand add very little lubrication to your engine.thank you for choosing fixya.com
Jan 10, 2011 | 1995 Nissan Pathfinder
My oil light is on, i have 39 miles on my gsxr 600. do i need an oil change or do i need to put oil in
Don't listen to the idot that said to change your oil at 39 miles! If you only have 39 miles on your bike and your oil light is on it mean there is low oil pressure so you need more oil in it. Cause the only reason that light goes on is when theres not enough oil in it. Not because you need an oil change.Also the oil change should be done at least every 3,000 miles but I do mine at 2,500. Also When you change the oil for the first time, you want to change the Filter as well. Every oil change there after you dont have to change the filter every time, you can do it every other oil change if you choose to. And always fill it up to in between the lines of your sight glass. and always makesure that after you put oil in it you start it up and for about 30-60 seconds then shut off and let sit for about an hour and add oil as needed.
Sep 18, 2009 | 2008 Suzuki GSX-R 600
Change oil light stays on after oil change
Did you also change the filter as well as the oil, and have the system flushed?
If not, do so.
Apr 17, 2009 | 2006 Chevrolet HHR
2006 ford exsplorer oil light did not go off after a oil change.
In the owners manual, you will find reset procedures.
I found this for ya, hope it helps!
Please Rate!
Oil Change Reset
A press of the OIL CHANGE RESET switch will allow you to
reset the oil life feature to 100% (or your Personalized Oil Reset
Percentage). After you have the oil changed, you must execute
the following procedure. Press the OIL CHANGE RESET switch
and hold for five seconds as the M/C counts down for five
seconds. After a successful reset the Message Center will display
“OIL LIFE RESET TO 100%.” If you have established a
Personalized Oil Reset Percentage, the display will show that
percentage instead of 100%. To ensure accurate oil life
indicators, perform this reset procedure only after an oil change.
Your Personalized Oil Reset Percentage allows you to establish a
smaller oil change interval than the manufacturer’s
recommended interval. To establish your Personalized Oil Reset
Percentage perform the following procedure:
1. Press and hold the OIL CHANGE RESET switch and press
the RESET switch while the display is still counting down
the 5 seconds to reset. The display will change to “START
OIL LIFE AT XXX%.”
2. Press the OIL CHANGE RESET switch until the displayed
percentage is the Personalized Oil Reset Percentage that you
desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%,
40% and 30%.
Mar 03, 2009 | 2006 Ford Explorer
No problem, just question on oil change,
I would recommend that you change your oil every 3,000 mile or 3 months which ever come first. This just help you keep a cleaner engine and keeps oil at Peak performance and provide excellent protection against sludge which developes with lack of oil change. Once a year seems too long for an oil change. However between oil changes you can add oil if needed. Good luck and thanks for using FIX YA
Jan 26, 2009 | 2006 Buick Lucerne
2006 Ford Explorer "Oil Change Required" light is still on after changing the oil
IF YOU FIND THIS INFO USEFUL PLEASE RATE ME AS A FIXYA! THANKS
Oil Change Reset
OIL LIFE AT XXX%.”
40% and 30%.
Oct 15, 2008 | 2006 Ford Explorer
Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
35 people viewed this question
Top Swisher Garden Experts
Tim Whalen
ray gallant
john milligan
Are you a Swisher Garden Expert? Answer questions, earn points and help others
